Import Demo into Eclipse
Joerg-SH
Post by Joerg-SH »
I try to add a Demo Projekt in Eclipse
Importing Makefile projects into Eclipse
The first step is to import a makefile project into the Eclipse environment. ChibiOS/RT demos do not include Eclipse project files but just a normal Makefile. Eclipse is able to import a Makefile project and create its own project file so this is not a problem. This is how it is done:
Open you Eclipse environment and select the workspace created into the ChibiOS/RT project directory.
From within Eclipse select “File→New→C_Project”, a dialog box will show.
Select “Makefile_project→Empty_Project” in the “Project type:” box.
Select ”– Other Toolchain –” in the “Toolchains:” box.
Unselect the “Use default location” check box.
Select the demo directory using the “Browse…” button. Something like ”C:\Projects\ChibiOS-RT\demos\ARMCM3-STM32F103-GCC” will appear in the “Location:” box.
In the project name box put the same name of the directory containing the demo, ”ARMCM3-STM32F103-GCC” in this example.
Compile and Run is no Problem but all sub directories missing and also eclipse mark a mistake of missing file
Unresolved inclusion: "ch.h"
how I can fix that?
Re: Import Demo into Eclipse
It is because Eclipse cannot "see" the files outside the demo directory. Create a new folder into the project (File->New->Folder) but instead giving it a name, select "Advanced..." and link it to the ./os folder of ChibiOS, then re-index the project (right click->index->rebuild). Eclipse should now be able to see all files and symbols.
Joerg-SH
Post by Joerg-SH »
Hello Giovanni,
thank You for Your help.
Thats works.
Now Eclipse shows a lot of errors like:
Description Resource Path Location Type
Symbol 'NULL' could not be resolved main.c /ARMCM4-STM32F407-DISCOVERY line 81 Semantic Error
I have to do more changes for eclipse properties?
Greetings
Joerg
Heh, that is the static code checker introduced in Eclipse Indigo, in their infinite wisdom it is always active by default, I just disabled it, too much noise.
Window->Preferences->C/C++->CodeAnalysis then disable all checks you don't want to see.
Hopefully it will improve in next versions, I hope they make it something you run when needed and not always active.
Joerg-SH
Post by Joerg-SH »
Ok thank You. It is a little bit confusing but I think I can live with it ;)
Tomorrow is the last Day of the Week for me and than I have more time to get more experience...
Next step ist to make the debugger run with eclipse. I think there will be more question than ;)
so long
Jörg
Joerg-SH
Post by Joerg-SH »
By the way...
I use True-studio lite for ST now.
I makes all a little bit easier as to use eclipse.
cambotero
Post by cambotero »
hi, I'm trying to work with the STM32L-discovery demo from chibios, and I had the same problems as Joerg-SH... after following your answers for solving them, I've found a new problem:
I'm using yagarto toolchain, and when I build the demo, it looks like eclipse don't recognise basic definitions like uint32_t, uint16_t... do you know what could be the problem with that?
First build the project at least one time then right click on the project in Eclipse and try to reindex it, Eclipse should rescan all symbols.
davidji
Post by davidji »
I think all the above problems are because the eclipse doesn't add the include folder from the cross compiler, and hence doesn't find <stddef.h> which includes NULL, size_t, uint32_t, uint16_t, etc. Once you add that by hand, the errors and warnings go away and there is no need to disable the static analysis.
