Correct procedure for entering WAITFOREVENT __WFE()
Tabulous
Has thanked: 7 times
Been thanked: 18 times
Post by Tabulous »
Hi
i'm trying to enter WFE, and want to wake backup when EXTI pin is asserted.
all the EXTI are working when running normally so i know its nothing to do with them.
using F101 device.
Re: Correct procedure for entering WAITFOREVENT __WFE()
The EXT driver should be able to handle this but I never tested the scenario, you need to enable an EXTI channel but the callback must be NULL, an event will be generated instead.
Tabulous
Post by Tabulous »
so this is what im doing, this is my test to enter WFE, which it does ok.
I have a break point after the last __WFE() on chSysUnlock(); When PA0/WAKEUP is stimulated, it wakes up, but it just jumps straight to hard fault!!!
int main( void )
static int timeout = 10;
     * System initializations.
     *   RTOS is active.
    debugInit();
    bootMessage();
    extStart( &EXTD1, &extio1 );
    DBGMCU->CR |= DBGMCU_CR_DBG_SLEEP | DBGMCU_CR_DBG_STOP;
    while (true)
        timeout--;
        TGL_DEBUG( DBG_MASK_APP,
                   "$ APP - Testing!\r\n" );
        if(timeout == 0)
            timeout = 10;
            palClearPad( GPIOA, GPIOA_GSM_PWR );
                       "$ APP - Entering Low Power State!\r\n" );
            chThdSleepMilliseconds( 5000 );
            /* clear PDDS and LPDS bits */
             PWR->CR &= ~(PWR_CR_PDDS | PWR_CR_LPDS);
             /* set LPDS and clear  */
             PWR->CR |= (PWR_CR_LPDS | PWR_CR_CSBF | PWR_CR_CWUF);
             /* Setup the deepsleep mask */
             SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
             chSysLock();
             __ISB();
             __SEV();
             __WFE();
             __WFE();
             chSysUnlock();
            /* clear the deep sleep mask */
            SCB->SCR &= ~SCB_SCR_SLEEPDEEP_Msk;
            /* reset the sytem to restart */
            __ASM volatile ("dsb");
            /* Keep priority group unchanged */
            SCB->AIRCR  = ((0x5FA << SCB_AIRCR_VECTKEY_Pos)      |        \
                           (SCB->AIRCR & SCB_AIRCR_PRIGROUP_Msk) |        \
                            SCB_AIRCR_SYSRESETREQ_Msk);
        chThdSleepMilliseconds( 1000 );
Tabulous
Post by Tabulous »
Revised working code, needed to use port_disable not chsyslock.
int main( void )
     *   RTOS is active.
    debugInit();
    bootMessage();
    while (true)
        timeout--;
        if(timeout == 0)
            timeout = 10;
             PWR->CR &= ~(PWR_CR_PDDS | \
                          PWR_CR_LPDS);
             PWR->CR |= (PWR_CR_LPDS | \
                         PWR_CR_CSBF | \
                         PWR_CR_CWUF);
             port_disable();
             __WFE();
             port_enable();
The equivalents would be chSysDisable() and chSysEnable().
