The Micro Pro is based on 328p, which doesn't have an EICRB register.
Trying to use the board file results in a compilation error on EICRB as undefined symbol.
The patch attached removes it.
Fix compilation bug for Micro Pro Topic is solved
Moderator: tfAteba
Re: Fix compilation bug for Micro Pro
Maybe this is related to this (old) bug:
https://sourceforge.net/p/chibios/bugs/758/
There are also those others that should be looked into:
https://sourceforge.net/p/chibios/bugs/666/
https://sourceforge.net/p/chibios/bugs/438/
viewtopic.php?f=21&t=3431
Giovanni wrote:https://sourceforge.net/p/chibios/bugs/438/
In general it looks like some code needs to be moved into macro/functions inside platform/board files: the AVR is a large family and there is significant variation, even within the subset that can be found on Arduino boards.
IMHO supporting the 2 or 3 most popular AVRs that can be found on Arduinos would go a long way.
That means (on top of my head) the 328p and 2560. But there might be some other very popular application that I'm not aware of.
I'm just a big fan of the Mini Pro.
On a side note: I suppose ChibiOS has some sort of CI system (from a quick search on the SF page i couldn't find more details).
Without going as far as deploying binaries on real HW, would it be possible to add AVR to the build targets?
On a 6 y.o. laptop I can build from scratch the entire OS and my application in about 10s, so it shouldn't be a resource hog.
Or maybe AVR is present, but only 2560?
We don't have a continuous integration system, the number of active developers is not that great. I would love to reach that at some point.
Since it's quite easy to integrate github with travis, adding support for travis in SVN should automatically enable the github mirror to trigger the builds/tests. I know of people who do this for cortex-m targets, never really seen for AVR. Would be a nice addition. I'm very short on time for the next days but can give it a try in the weekend.
utzig wrote:Since it's quite easy to integrate github with travis, adding support for travis in SVN should automatically enable the github mirror to trigger the builds/tests. I know of people who do this for cortex-m targets, never really seen for AVR. Would be a nice addition. I'm very short on time for the next days but can give it a try in the weekend.
Definitely!
I had the same idea: I waited (too long?) for submitting patches because I didn't feel like learning svn, then eventually I decided to bite the bullet, but luckily I found out about git-svn, so I can use git and ignore the svn backend. I already had in mind to learn Travis, this could be a good exercise. So maybe I can do it sooner. I found out this: https://www.willglynn.com/2014/02/20/av ... travis-ci/
Btw, while talking about git-based automation, Coverity provides free scans for OSS hosted on github and they also support integration with Travis.
I already tried it on my ChibiOS-based projcet and it works nicely. I am still missing the Travis part, though.
I'm not sure what board you actually have but there is some "naming" issue going on. The PRO MICROs actually have an ATmega32u4 which does have EICRB! The two available at SparkFun:
https://www.sparkfun.com/products/12587
https://www.sparkfun.com/products/12640
I have the 3.3V one and used it to test/integrate the contributed USB driver, which means, I created the demo/board and tested it!
Maybe what you have the PRO MINI?
https://www.sparkfun.com/products/11114
That one has a 328p. Or there is another one that is really called Micro Pro instead of Pro Micro?
Fabio Utzig
Fabio Utzig
Igor,
Regarding travis you probably can test the yaml on your own fork to get it to a working stage (ok, I'm stating the obvious!). When you get something already working please submit a patch and I'll apply to SVN.
Also I need to talk to barthess about automating the mirror synching because it seems to still be done manually and I have some spare VPSs which I could let running a cron job for doing it. Not ideal because we'll still have to wait like 10 or 15 minutes to get the build results but way better than not having this at all. Also since git it out of question, I think, that is the best way to go for now.
Btw, someone that is already building for arm cortex-m on github/travis:
https://github.com/gt-quadcopter/crazyf ... travis.yml
Cheers,
Fabio Utzig
Cheers,
Fabio Utzig
utzig wrote:I'm not sure what board you actually have but there is some "naming" issue going on. The PRO MICROs actually have an ATmega32u4 which does have EICRB! The two available at SparkFun:
Fabio Utzig
Yes, you are right. I do not use the ones from sparkfun, but rather the cheap $2-a-pop clones from ebay, where the terms Mini/Micro are often used interchangeably and I ended up doing the same
Some have actually better pin layout, imho.
See picture attached: I can have all the pins at the bottom, plus additional I2C and flashing headers.
