GCC versions?
mobyfab
Has thanked: 21 times
Been thanked: 31 times
GCC versions?
Post by mobyfab »
So I'm trying a bunch of GCC versions, with and without LTO, with and without FPU. Latest ChibiOS/RT.
So far the only version that fully works is 4.8, 4.7 used to work without LTO.
I have tried 4.9, 5.2, 5.4, all from ARM.
This is for an STM32F303.
Did anyone have some luck with some of these versions?
Re: GCC versions?
4.9 is included in ChibiStudio and works, I am working with 5.2 also. All taken from here: https://launchpad.net/gcc-arm-embedded
You need to provide example of things that do not work as expected and specify if it is a self-built compiler.
mobyfab
Re: GCC versions?
Post by mobyfab »
These are all from ARM as I said, same link as you.
I will make some tests with my F3 discovery board, right now I only tried to compile my project which uses a custom board.
Edit: it seems to work fine on the discovery board with 5.4, FPU and LTO (USB CDC Example)
Re: GCC versions?
It would be important to have something reliably not working with specific versions.
mobyfab
Re: GCC versions?
Post by mobyfab »
Yes,
I was actually caused by the ARM DSP library. I updated it to CMSIS 5 and it works fine now. (https://github.com/ARM-software/CMSIS_5)
I'm using GCC 5.4.
