Bootloader vector table problem Topic is solved
Tabulous
Has thanked: 7 times
Been thanked: 18 times
Re: Bootloader vector table problem
Post by Tabulous »
you can still debug without changing the the location, i do this without issues.
Are you using chibistudio and open ocd ?
doddi
Post by doddi »
Hmm, thats what I thought you should be able to do. Have you done this by first doing a complete erase of your flash device (i.e. no bootloader or 'original' vector table)
Im running on a linux machine using openOCD and eclipse with the plugin
Im wondering if it might be something to with my arm compiler version. Are you able to tell me what version you are using? Im building with arm-none-eabi-gcc version 4.7.4 20140401
doddi
Post by doddi »
I have now tried with gcc 4.9 and 5.2 with the same problem. All works fine if I have bootloader and app programmed but not when I erase bootloader :cry:
I suspect this is how it is but most people wouldn't have realised, presumably openOCD will only erase what it is about to programme, whereas I have been doing "stm32f1x mass_erase 0" to erase all of flash
Tabulous
Post by Tabulous »
doddi wrote:I have now tried with gcc 4.9 and 5.2 with the same problem. All works fine if I have bootloader and app programmed but not when I erase bootloader :cry:
you need bootloader programmed underneath
i'm using 4.9
doddi
Post by doddi »
i'm using 4.9
Thanks for the input, I think I have been chasing my tail with another issue in that case!
Can you tell me which complete version of gcc you have please? Mine is 4.9.3 and last time I had other runtime issues for mounting the SD card, some of the function in libgcc arent working correctly with chibios
doddi
Post by doddi »
It turns out it is something to do with gcc 4.9.
Although it compiles there doesnt seem to be a strcmp available and it is this that is causing the unhandled_exception. It is probably an issue with the rules.ld file that I am using as part of the ChibiOS I was given for this project.
I dont have time to investigate any further but 4.7.4 seems to work fine. I have read in a few places that it might have something to do with eh_frame's?
