STM32F103 i2c won't work with MPU6050
Fulcrum Mike
Re: STM32F103 i2c won't work with MPU6050
Post by Fulcrum Mike »
Hi
Try increasing I2C IRQ priorities above the other sources, 5 for example, and see if it makes a difference.
The IRQ priorities for both I2C1 and I2C2 were already 5. I changed it to 7. Same issue.
Some other common issues are listed in this article: http://wiki.chibios.org/dokuwiki/doku.p ... e_shooting
I already studied this guide before opening this thread.
After numerous resets, I was once able to read the correct values with two different i2c read requests. Output:
Init error: 0
Add: 34
Sleep: 1
Yet the next reset produced the same error again:
Init error: 0
Add: 34
I2C STATUS: -1
I2C ERROR: 0
Sleep: 0
Just hooked the sensor module to rpi-3. Works like a charm.
I have read virtually all the posts on this forum about I2C, and still got no idea whats bugging my very simple code.
Note that lower numbers are higher priorities. Do you have IRQ priorities numerically below 5?
Fulcrum Mike
Oopss.. I should have checked before assuming.
No, all other IRQs are above 5.
Koen
Been thanked: 5 times
Post by Koen »
If I recall correctly, early STM32 had major I2C hardware problems and ST later released a library named CPAL to help deal with it.
Have you seen this : https://github.com/jevermeister/MPU6050 ... S/issues/2 ?
"To get the library to function and detect the MPU6050, I had to modify the I2CdevreadBytes function to add in specific support for the STM32F103 chip as in Chibios/Hardware, you are unable to read a single byte from the I2C bus."
Koen
Post by Koen »
Did you enable debug checks in chconf.h ? I checked the repository and the code should trigger an error as you are asking to receive 1 byte :
msg_t i2c_lld_master_receive_timeout(I2CDriver *i2cp, i2caddr_t addr,
                                     uint8_t *rxbuf, size_t rxbytes,
                                     systime_t timeout) {
#if defined(STM32F1XX_I2C)
  osalDbgCheck(rxbytes > 1);
msg_t i2c_lld_master_transmit_timeout(I2CDriver *i2cp, i2caddr_t addr,
                                      const uint8_t *txbuf, size_t txbytes,
  osalDbgCheck((rxbytes == 0) || ((rxbytes > 1) && (rxbuf != NULL)));
Fulcrum Mike
A similar thread was opened in this forum too. I thought that the problem would have been solved by now. :oops:
I am now using a very simple approach by manually using i2cMasterTransmitTimeout instead of using MPU6050-ChibiOS. The good thing:By reading in burst mode, I can make several transactions without getting the earlier erros. The bad thing: The data received is not correct. Reading in burst mode and then chprinting the required register returns incorrect value. For example:
    //READ DATA IN BURST
    chprintf((BaseSequentialStream*)&SD2, "==Read Data:==: \n\r");
    status = MSG_OK;
    i2cAcquireBus(&I2CD2);
    tx_data[0] = 0x3B; //Accel_data
    status = i2cMasterTransmitTimeout(&I2CD2, 0x68,tx_data, 1, rx_data, 14, tmo);
    i2cReleaseBus(&I2CD2);
    if(status == MSG_TIMEOUT || status == MSG_RESET) {
        chprintf((BaseChannel *)&SD2,"I2C STATUS: %d\n\r", status);
        chprintf((BaseChannel *)&SD2,"I2C ERROR: %d\n\r", i2cGetErrors(&I2CD2));
    chThdSleepMilliseconds(2000);
    chprintf((BaseSequentialStream*)&SD2, "%d %d %d %d %d %d %d %d %d %d %d %d %d %d\n\r", rx_data[0], rx_data[1],rx_data[2],rx_data[3],rx_data[4],rx_data[5],rx_data[6],rx_data[7],rx_data[8],rx_data[9],rx_data[10],rx_data[11],rx_data[12],rx_data[13]);
This code returns the current value for 3D accel, 3D gyro, and temperature. But all I am getting is this:
==Read Data:==:       //No 'I2C ERROR' output, meaning the transaction returned MSG_OK
0 0 255 0 0 0 0 0 0 0 0 0 0 0   //The register values. These are very likely incorrect
Won't give up now :evil:
Koen
Post by Koen »
It's an hardware error in F1 : it won't be fixed, ever. You can only work-around it. Anyway, enable debug checks to avoid these easy traps.
Also try avoiding reading a single byte, minimum two, it is another errata of the F1 I2C.
Fulcrum Mike
Thank you all for your help and suggestions.
Finally, I am able to read correct data, and write to configuration registers of the MPU6050 module.
The only difference between my working code and earlier code is that earlier, I was trying to read WHO_AM_I byte (single byte read operation) at startup, which froze the I2C driver, hence making later transactions fail.
Now I am reading the sensor data in burst mode (14 registers at once starting at 0x3B). It's working as expected. To read a single byte, I read multiple bytes and discard the extra data.
Cheers
