Trying to get lwIP to work Topic is solved
Pethead
Re: Trying to get lwIP to work
Post by Pethead »
Ok thanks, found this thread as well where you say that the PLL introduces too much jitter and that I need an external oscillator, is that really the case?
I never experimented with it, it was something found on an ST datasheet or application note.
Pethead
Post by Pethead »
I have re-checked the PIN setup multiple times and I can't find any problems in that setup, the reference clock is 50 MHz and I can't find anything about any specific PHY initialization in the LAN8720A datasheet (maybe I'm just bad at reading datasheets...?).
I'm using this MCU board (With an 8 MHz external crystal) and the LAN8720A transceiver mentioned above (which is also present in the schematic).
I'm using a STM32F407
(I've attached the full project and a picture of the reference clock for the LAN8720A chip, if anyone has the time and effort to actually look at it)
The is the pin configuration I am using:
PA2  - ETH_MDIO         (alternate 11)
PA7 - ETH_RMII_CRS_DV (alternate 11)
PA8 - MCO1 (alt 0 configured with PLL to 50 MHz)
PB10 - RXER (input, optional)
PB11 - ETH_RMII_TXEN (alternate 11)
PB12 - ETH_RMII_TXD0 (alternate 11)
PB13 - ETH_RMII_TXD1 (alternate 11)
PB14 - nINT (output)
PC1 - ETH_MDC (alternate 11)
PC4 - ETH_RMII_RXD0 (alternate 11)
PC5 - ETH_RMII_RXD1 (alternate 11)
The program gets stuck during the initialization in the mac_lld_start() function in mac_lld.c at the following section and just loops there endlessly, and I have no idea of to make it get past the start function.
/* Transmit FIFO flush.*/
  ETH->DMAOMR   = ETH_DMAOMR_FTF;
  while (ETH->DMAOMR & ETH_DMAOMR_FTF)
I don't know if the reference clock looks okay, but it is a 50 MHz signal as you can see in the picture.
Would appreciate if someone could take a look at it but I guess that requires some effort.
ethernet.tar.7z
(4.66 MiB) Downloaded 340 times
Without HW to test it is pointless to look at the code. Is MCO programmed for maximum speed? that 50MHz signal does not look like a square wave, an HW issue is also possible.
One option is to get one of the supported boards and compare with your board.
Pethead
Post by Pethead »
Okay, I just thought that someone might run it on their board to see if they have the same problem, if they just had the time to re-configure the pins. Was just wondering since I don't have any other board available right now. I only have an STM32F4-Discovery but I don't have an external ethernet PHY to test it against, still waiting on it.
Yes the MCO1 PIN is configured for high speed "PIN_OSPEED_HIGH(GPIOA_MCO1)" in board.h
Yes I was a bit skeptical regarding the 50 MHz reference clock signal. Worse case I'll replace the 8 MHz crystal with a 25 MHz one and see if it looks better, but hopefully that is not the problem, but who knows...
The new Nucleo144 boards have Ethernet and are really cheap, you may consider one of those as "reference".
Pethead
Post by Pethead »
Okay I found the problem for why it was getting stuck... When I decided to use MCO1 instead of ETH_RMII _REF_CLK as the reference clock out from the MCU I disabled the ETH_RMII_REF_CLK pin function since I thought I could use either one of those out from the MCU as the reference clock, I did not think that the ETH_RMII_REF_CLK was actually needed as a reference clock for the mac driver...
Gonna try and see if I can get the webserver demo working.
Pethead
Post by Pethead »
The webserver works (Yay!). However, it only works if I clear the Ethernet MAC clock enable bit BEFORE the call to lwipInit(NULL); So my guess is that there is some conflict with some other peripheral that I have configured.
This is not required in other demos, very strange.
Pethead
Post by Pethead »
I cleared the whole RCC_AHB1ENR peripheral clock enable register and apparently that made it work since I had configured PC1 for ADC sampling in some ADC sampling code that I was testing and still had running on the MCU but wasn't really being used for anything, so there was a conflict between the ADC pin configuration and the Ethernet pin configuration since PC1 was used for ETH_MDO... So yea, just stupid problems.
