Target STM32F411
board.h defined like this
* MCU type as defined in the ST header.
#define STM32F411xE
as you can see the correct header file is not used and also the error is never shown.......
Not using correct header
Re: Not using correct header
Tabulous wrote:Target STM32F411
#define STM32F411xE
PS ive tried rebuilding the Index
- RoccoMarco
- Has thanked: 83 times
- Been thanked: 67 times
is it a custom demo or an official one?
Can you share board.h and makefile?
Please wrap them in code tag.
RoccoMarco wrote:Hi,
Its custom board
ChibiOS - Copyright (C) 2006..2015 Giovanni Di Sirio
#ifndef _BOARD_H_
#define _BOARD_H_
* Setup for Test board.
* Board identifier.
#define BOARD_TG_T721121601
#define BOARD_NAME "Test"
* Board oscillators-related settings.
* NOTE: HSE not fitted.
#if !defined(STM32_LSECLK)
#define STM32_LSECLK 32768U
#if !defined(STM32_HSECLK)
#define STM32_HSECLK 0U
* Board voltages.
* Required for performance limits calculation.
#define STM32_VDD 300U
#define STM32F411xE
* IO pins assignments.
board.mk
# List of all the board related files.
BOARDSRC = ${CHIBIOS}/os/hal/boards/TG_T721121601/board.c
# Required include directories
BOARDINC = ${CHIBIOS}/os/hal/boards/TG_T721121601
makefile
# Build global options
# NOTE: Can be overridden externally.
# Compiler options here.
ifeq ($(USE_OPT),)
USE_OPT = -O0 -ggdb -fomit-frame-pointer -falign-functions=16
endif
# C specific options here (added to USE_OPT).
ifeq ($(USE_COPT),)
USE_COPT =
endif
# C++ specific options here (added to USE_OPT).
ifeq ($(USE_CPPOPT),)
USE_CPPOPT = -fno-rtti
endif
# Enable this if you want the linker to remove unused code and data
ifeq ($(USE_LINK_GC),)
USE_LINK_GC = yes
endif
# Linker extra options here.
ifeq ($(USE_LDOPT),)
USE_LDOPT =
endif
# Enable this if you want link time optimizations (LTO)
ifeq ($(USE_LTO),)
# USE_LTO = yes
USE_LTO = no
endif
# If enabled, this option allows to compile the application in THUMB mode.
ifeq ($(USE_THUMB),)
USE_THUMB = yes
endif
# Enable this if you want to see the full log while compiling.
ifeq ($(USE_VERBOSE_COMPILE),)
USE_VERBOSE_COMPILE = no
endif
# If enabled, this option makes the build process faster by not compiling
# modules not used in the current configuration.
ifeq ($(USE_SMART_BUILD),)
USE_SMART_BUILD = yes
endif
# Architecture or project specific options
# Stack size to be allocated to the Cortex-M process stack. This stack is
# the stack used by the main() thread.
ifeq ($(USE_PROCESS_STACKSIZE),)
USE_PROCESS_STACKSIZE = 0x400
endif
# Stack size to the allocated to the Cortex-M main/exceptions stack. This
# stack is used for processing interrupts and exceptions.
ifeq ($(USE_EXCEPTIONS_STACKSIZE),)
USE_EXCEPTIONS_STACKSIZE = 0x400
endif
# Enables the use of FPU on Cortex-M4 (no, softfp, hard).
ifeq ($(USE_FPU),)
USE_FPU = no
endif
# Project, sources and paths
# Define project name here
PROJECT = t7_app
# Imported source files and paths
CHIBIOS = ../../..
# Startup files.
include $(CHIBIOS)/os/common/ports/ARMCMx/compilers/GCC/mk/startup_stm32f4xx.mk
# HAL-OSAL files (optional).
include $(CHIBIOS)/os/hal/ports/STM32/STM32F4xx/platform.mk
include $(CHIBIOS)/os/hal/boards/TG_T721121601/board.mk
include $(CHIBIOS)/os/hal/osal/rt/osal.mk
# RTOS files (optional).
include $(CHIBIOS)/os/rt/rt.mk
include $(CHIBIOS)/os/rt/ports/ARMCMx/compilers/GCC/mk/port_v7m.mk
# Other files (optional).
#include $(CHIBIOS)/test/rt/test.mk
# Define linker script file here
LDSCRIPT= $(STARTUPLD)/STM32F411xC_T7APP.ld
# C sources that can be compiled in ARM or THUMB mode depending on the global
# setting.
CSRC = $(STARTUPSRC) \
$(KERNSRC) \
$(PORTSRC) \
$(OSALSRC) \
$(HALSRC) \
$(PLATFORMSRC) \
$(BOARDSRC) \
$(CHIBIOS)/os/various/syscalls.c \
$(CHIBIOS)/os/hal/lib/streams/chprintf.c \
$(CHIBIOS)/os/hal/lib/streams/memstreams.c \
main.c cdc.c debug.c shell.c vt100.c usbcfg.c \
gnss.c except.c console.c modem.c athandler.c \
als.c psu.c ble.c imu.c flash.c
# C++ sources that can be compiled in ARM or THUMB mode depending on the global
# setting.
CPPSRC =
# C sources to be compiled in ARM mode regardless of the global setting.
# NOTE: Mixing ARM and THUMB mode enables the -mthumb-interwork compiler
# option that results in lower performance and larger code size.
ACSRC =
# C++ sources to be compiled in ARM mode regardless of the global setting.
ACPPSRC =
# C sources to be compiled in THUMB mode regardless of the global setting.
TCSRC =
TCPPSRC =
# List ASM source files here
ASMSRC = $(STARTUPASM) $(PORTASM) $(OSALASM)
INCDIR = $(STARTUPINC) $(KERNINC) $(PORTINC) $(OSALINC) \
$(HALINC) $(PLATFORMINC) $(BOARDINC) \
$(CHIBIOS)/os/hal/lib/streams \
# Compiler settings
MCU = cortex-m4
#TRGT = arm-elf-
TRGT = arm-none-eabi-
CC = $(TRGT)gcc
CPPC = $(TRGT)g++
# Enable loading with g++ only if you need C++ runtime support.
# NOTE: You can use C++ even without C++ support if you are careful. C++
# runtime support makes code size explode.
LD = $(TRGT)gcc
#LD = $(TRGT)g++
CP = $(TRGT)objcopy
AS = $(TRGT)gcc -x assembler-with-cpp
AR = $(TRGT)ar
OD = $(TRGT)objdump
SZ = $(TRGT)size
HEX = $(CP) -O ihex
BIN = $(CP) -O binary
US = binsize 128 256 build\\t7_app.elf
# ARM-specific options here
AOPT =
# THUMB-specific options here
TOPT = -mthumb -DTHUMB
# Define C warning options here
CWARN = -Wall -Wextra -Wundef -Wstrict-prototypes
# Define C++ warning options here
CPPWARN = -Wall -Wextra -Wundef
# Compiler settings
# Start of user section
# List all user C define here, like -D_DEBUG=1
UDEFS =
# Define ASM defines here
UADEFS =
# List all user directories here
UINCDIR =
# List the user directory to look for the libraries here
ULIBDIR =
# List all user libraries here
ULIBS = -lm
# End of user defines
RULESPATH = $(CHIBIOS)/os/common/ports/ARMCMx/compilers/GCC
include $(RULESPATH)/rules.mk
Is that a compilation error or just an Eclipse quirk? if it is related to Eclipse try erasing discovered paths, recompile and reindex.
Giovanni wrote:Is that a compilation error or just an Eclipse quirk? if it is related to Eclipse try erasing discovered paths, recompile and reindex.
Everything compiles ok(i think, well it seems to work), but normally you can press F3 when on a SYSTEM define and it will jump to the header file.
Well what it is doing is jumping to the wrong header file.
i.e. I highlight SPI_CR1_BR_0 in source file and press F3, it should jump to stm32f411xe.h header, but it doesn't, it jump to stm32l486xx.h.
Ive tried to clear the discoverable paths in properties -> C/C++ Build "Discovery Options" and then re-build the index, but still the same.
It is eclipse getting confused by the multiple headers in the same directory. I think we cannot address it, you may remove unrelated headers from your source tree.
