Serial Driver flush buffer
vrollei
Been thanked: 26 times
Post by vrollei »
Hi!
Does it possible to flush serial driver buffer?
Thanks in advance!
Re: Serial Driver flush buffer
If you want to erase all the buffered content there are two ways:
1) Read and discard all content using TIME_IMMEDIATE, you get MSG_TIMEOUT when the queue is empty.
2) Reset the queue directly using iqResetI().
osalSysLock();
isResetI();
osalOsRescheduleS();
osalSysUnlock();
You may use "ch" function instead of "osal" functions, it is the same.
vrollei
Post by vrollei »
I mean output buffer, is there any method to force driver process all output buffer to implement this scenario:
sdStart();
chprintf("log message");
// force driver to process log message before stop it
sdStop();
There is a specific event flag for transmission complete, you need to wait for that.
vrollei
Post by vrollei »
Thanks!
vrollei
Post by vrollei »
Hi, Giovanni!
Is this right way to wait transmission complete:
[font=Courier New]event_listener_t serial_listener;
chEvtRegisterMaskWithFlags(&(SD2.event), &serial_listener, EVENT_MASK(0), CHN_TRANSMISSION_END);
sdStart(&STDOUT_SD, &SD2Config);
<write to STDOUT_SD>
while (true) {
chEvtWaitAny(EVENT_MASK(0));
if (chEvtGetAndClearFlags(&serial_listener) & CHN_TRANSMISSION_END) {
break;
sdStop(&STDOUT_SD);[/font]
It looks OK.
steved
Has thanked: 12 times
Been thanked: 138 times
Post by steved »
At risk of stating the obvious, dependent on your application you may need to check that there is a transmission in progress before waiting for it to complete. Or just add a timeout into the event wait.
vrollei
Post by vrollei »
is there no queue for events? In this case you are right, there is a chance to wait forever.
Can not figure out how to check that transmission is in progress....
Events are bit masks, there is no queuing. You need to make sure there are no events pending before starting transmission.
