EXTI - single execution (one shot)
Skadi
Has thanked: 4 times
Been thanked: 3 times
Post by Skadi »
I implemented an extrenal interrupt, which is configured as followed:
static EXTConfig extern_interrupt_config = { {
        {EXT_CH_MODE_DISABLED, NULL},
        {EXT_MODE_GPIOC | EXT_CH_MODE_RISING_EDGE | EXT_CH_MODE_AUTOSTART, adc_sync_callback},         /* Pin PC7 */
The callback function:
void adc_sync_callback (EXTDriver *ext_driver, expchannel_t channel){
    (void)ext_driver;
    (void)channel;
    chSysLockFromISR();
    Do_Someting();
    extChannelDisableI(&EXTD1, 7);
    chSysUnlockFromISR();
The "execution" in the main programm:
  extStart(&EXTD1, &extern_interrupt_config);
  extChannelEnable(&EXTD1, 7);
The extrenal interrupt works, but it is executed twice. I tried to set the interrupt pending bit to 1 (as stated in the reference manuel on page 388) by
EXTI->PR |= 0x00000010;
but it makes no difference.
How can I achive a single execution?
BR Skadi
Re: EXTI - single execution (one shot)
EXTI is edge sensitive, not sure what is going on there.
Status flags are cleared by the driver, you don't need to do that yourself.
Skadi
Post by Skadi »
I know, EXTI is edge sensitive. In may case I set the trigger sensitive to an rising edge.
An clock signal is attached to the extrenal trigger pin, thus I disable the interrupt inside callback function. Unfortunately the callback function is executed twice instead of a single time.
So if the status flags are cleared by the driver, why is the callback function executed twice?
BR
Skadi
The channel disable function clears the PR register so I don't see how you are getting another callback.
I don't see anything in the code that could trigger that.
Try to write a test application that is triggered by the board button then disables the channel. See if you get the same behavior.
