https://github.com/gaudat/chinkboard-ads1256
The version of ChibiOS I'm using is pulled from https://github.com/ChibiOS/ChibiOS a week ago.
It gives error like this:
In file included from ../ChibiOS/os/hal/include/hal_pal.h:129:0,
from ../ChibiOS/os/hal/include/hal.h:124,
from ./modules/load_cell/scale.c:10:
./modules/load_cell/scale.c: In function 'updateLed':
../ChibiOS/os/hal/ports/STM32/LLD/GPIOv2/hal_pal_lld.h:484:50: error: request for member 'H' in something not a structure or union
#define pal_lld_setport(port, bits) ((port)->BSRR.H.set = (uint16_t)(bits))
../ChibiOS/os/hal/include/hal_pal.h:286:32: note: in expansion of macro 'pal_lld_setport'
#define palSetPort(port, bits) pal_lld_setport(port, bits)
../ChibiOS/os/hal/include/hal_pal.h:454:30: note: in expansion of macro 'palSetPort'
#define palSetPad(port, pad) palSetPort(port, PAL_PORT_BIT(pad))
./modules/load_cell/scale.c:160:9: note: in expansion of macro 'palSetPad'
palSetPad(LED_PORT,LED_R);
../ChibiOS/os/hal/ports/STM32/LLD/GPIOv2/hal_pal_lld.h:496:52: error: request for member 'H' in something not a structure or union
#define pal_lld_clearport(port, bits) ((port)->BSRR.H.clear = (uint16_t)(bits))
../ChibiOS/os/hal/include/hal_pal.h:306:34: note: in expansion of macro 'pal_lld_clearport'
#define palClearPort(port, bits) pal_lld_clearport(port, bits)
../ChibiOS/os/hal/include/hal_pal.h:473:32: note: in expansion of macro 'palClearPort'
#define palClearPad(port, pad) palClearPort(port, PAL_PORT_BIT(pad))
./modules/load_cell/scale.c:162:9: note: in expansion of macro 'palClearPad'
palClearPad(LED_PORT,LED_R);
./modules/load_cell/scale.c:165:9: note: in expansion of macro 'palSetPad'
palSetPad(LED_PORT,LED_G);
./modules/load_cell/scale.c:167:9: note: in expansion of macro 'palClearPad'
palClearPad(LED_PORT,LED_G);
./modules/load_cell/scale.c:170:9: note: in expansion of macro 'palSetPad'
palSetPad(LED_PORT,LED_B);
./modules/load_cell/scale.c:172:9: note: in expansion of macro 'palClearPad'
palClearPad(LED_PORT,LED_B);
As pal_lld_setport is for internal use, I don't know whether it is appropriate to change the code.
I know STM32F1xx uses GPIOv1 and STM32F0xx uses GPIOv2, but I don't know what is the difference that caused the problem.
Thank you.
