Hi
the STM32F7 HAL is missing the code to set the LSEDRV bits.
STM327 HAL missing LSEDRV Topic is solved
- 0001-stm32f7xx_hal_lld-add-missing-LSEDRV-config.zip
- (1.1 KiB) Downloaded 450 times
Re: STM327 HAL missing LSEDRV
The patch is not enough, it requires the value to be exported by the board files which will require a change in the generator tool.
Suspended.
Suspended.
Patched generator files.
The default is "Low driving capability" and can cause problems like clock-jitter and very unprecise time.
- f7-chibistudio.zip
- (3.86 KiB) Downloaded 416 times
Thanks for the patch and changes to the generator, you got it mostly right, just the XML schema was missing.
