LWIP - OUT OF MEMORY Topic is solved
Skadi
Has thanked: 4 times
Been thanked: 3 times
Post by Skadi »
I'm struggling to read out data via ethernet when I execute the function (FUNCTION()) below a second time.
I'm using LWIP. I send two commands to the microcontroller, the number of samples and iterations.
When I do that once, everything works as it should. But if the function is excecuted a second time the microcontroller seems to get stuck (increase of supply current).
I checked the receive errors recv_err. When I excecute the function a second time the secend receive error returns -1, which stands for Out of memory. I have no clue how to fix this, is the use of NETCONN_COPY a problem? If so, how can I delete the memory occupied by "NETCONN_COPY". I can not use NETCONN_NOCOPY, otherwise my data inside the for loop gets corrupted.
I am grateful for every advice, I already spent two days trying to fix the proplem
BR
Skadi
static void FUNCTION(struct netconn *conn) {
    struct netbuf *buf;
    unsigned int *data;
    uint16_t len;
    err_t recv_err;
    uint16_t samples;
    uint16_t iterations;
    unsigned int k;
    recv_err = netconn_recv(conn, &buf);
    if (recv_err == ERR_OK) {
        netbuf_data(buf, (void **)&data, &len);
        samples = data[0];
        iterations = data[0];
      for(k=0; k<iterations; k++){
   >> DO SOMETHING leading to DATA <<
         netconn_write(conn, DATA, samples, NETCONN_COPY);
        netbuf_delete(buf);
Re: LWIP - OUT OF MEMORY
I cannot help much with lwIP. There are a couple of open problems regarding lwIP in the bug reports forum, you may try to see if the proposed solutions work for you.
viewtopic.php?f=35&t=3866
viewtopic.php?f=35&t=3855
Skadi
Post by Skadi »
thank you for the quick reply!
The first link looks promising. I will have a closer look tomorrow, enough for today ;) .
THX
Skadi
Skadi
Post by Skadi »
I had a closer look at both links. I wasn't able to fix my problem according to them.
To fix the problem, I send boht values samples and iterations at once. I have no clue why this makes a difference, but it works fine for me. I will test my program extensively and look if it is stable ;) .
BR
Skadi
steved
Has thanked: 12 times
Been thanked: 138 times
Post by steved »
I've just posted updates to the latest version of lwIP - V2.0.2
Always possible that might affect your problem (and they could do with more testing!)
