Adding an argument to PAL event callbacks Topic is solved
Re: Adding an argument to PAL event callbacks
It makes sense, I will add switches to disable single ISRs without impacting others.
FXCoder
Has thanked: 188 times
Been thanked: 134 times
Post by FXCoder »
Thanks Giovanni.
I see you were busy on the weekend and the defines are there.
I added definitions in mcuconf.h for PAL vector override.
For consistency can I suggest adopting the same structure as used for other settings so that the setting can be explicitly shown (TRUE/FALSE)?
More work I know...
In mcuconf.h
 * PAL driver system settings.
#define STM32_DISABLE_EXTI1_HANDLER         TRUE
etc...
Then in stm32_isr.c
#if !STM32_DISABLE_EXTI1_HANDLER
 * @brief   EXTI[1] interrupt handler.
 * @isr
etc...
And in stm32_isr.h
 * @name    Configuration options
 * @brief   EXTI0 interrupt override setting.
#if !defined(STM32_DISABLE_EXTI0_HANDLER) || defined(__DOXYGEN__)
#define STM32_DISABLE_EXTI0_HANDLER         FALSE
etc...
I prefer to not bring so many arcane switches in mcuconf.h, it is already quite complex as is. I think simple definitions are fine for this use case and need no checks.
FXCoder
Post by FXCoder »
OK.
So the preferred location is still mcuconf.h but just as plain #defines.
Correct?
Correct, in alternative twitches could be placed in makefiles -D...
