UART line idle handling.
barthess
Re: UART line idle handling.
Post by barthess »
1) User have to explicitly set appropriate flags in CRx registers to get timeout interrupt/callback. If user wants old (without timeout) behaviour than he just fill new fields in config structure to NULL/0 values. No other changes needed.
2) Added it. Any way I do not use synchronous API for UART and can not evaluate its convenience in appliance to timeout. Hope it will be useful.
It looks good so far, thanks, it is a very useful feature.
barthess
Post by barthess »
@Giovanni
Why this checks needed?
(cr1 & USART_CR1_IDLEIE) (cr1 & USART_CR1_RTOIE)
They are redundant from my point of view. May be any errata notes I am missed?
We don't want to serve those interrupt flags if not explicitly enabled in CR1. Without those checks you could spuriously call the timeout callback when another kind of error triggers the ISR.
kimmoli
Has thanked: 11 times
Been thanked: 8 times
Post by kimmoli »
Noticed that IDLE interrupt mechanism is missing from USARTv1, altough atleast F4 USART has this functionality.
I think adding support would be a simple task (see below). We will test this on monday with DMA reception, but afaiu the callback definition (_uart_timeout_isr_code()) is in the include that is common for both.
https://github.com/kimmoli/ChibiOS/comm ... 89ca7707c7
Or am i missing something?
(apologies for necromancing an old thread)
It should work, it is just missing.
kimmoli
Post by kimmoli »
Although my changes had some errors... missing the timeout_cb from USARTConfig struct, and typo in USART_ISR_IDLE (Should be USART_SR_IDLE)
(https://github.com/kimmoli/ChibiOS/commits/usartv1_idle)
Korken
Has thanked: 5 times
Been thanked: 6 times
Post by Korken »
Will you add this? It does not seems to have been added to trunk.
michael_s
Post by michael_s »
Hello Giovanni,
I would like to upvote this feature also as we need free bus detection for our RS-485 implementation.
In addition to checking USART_SR_IDLE, it would be necessary to check the BUSY flag (bit 16)in USART_ISR register also, since USART_SR_IDLE is only set by hardware once an idle condition is present and not cleared in case the bus becomes busy in the meantime. So, I would propose:
/* Timeout interrupt source is only checked if enabled in CR1 and if BUSY flag is not set.*/
if ((sr & USART_ISR_IDLE) && (cr1 & USART_CR1_IDLEIE) && (sr & 0x10000U) {
  _uart_timeout_isr_code(uartp);
BUSY flag is hardcoded (0x10000U) since CMSIS header does not provide it.
What do you think?
Could you please post it in the "change requests" forum? it is hard to remember all posts.
"bug reports" and "change requests" are actively monitored.
