Mailboxes and queues examples?
kermitas
Post by kermitas »
Hello everybody, hello Giovanni :).
If there are no stupid questions ... I wonder to know where can I find mailboxes and queues usage examples??
Arthur.
Re: Mailboxes and queues examples?
Hi Arthur,
You may look into the test code under ./test, you can find there examples for all kernel functions, feel free to ask questions on the forum if you have any doubt. Device drivers are also good examples for Queues, Semaphores and Events.
Consulting documentation while browsing the code is also a good idea. :)
Ah, for mailboxes look at the "IRQ_STORM" demos under ./testhal, MBs are used heavily there.
utzig
Been thanked: 20 times
Post by utzig »
The test/ directory in the sources root has examples for most kernel features. In specific you should look to test/testmbox.c and test/testqueues.c.
Fabio Utzig
kermitas
Post by kermitas »
Thans :).
I didn't know where to start.
I am thinkig about something similar to actors model - like in Scala (www.akka.io) or Erlang:
- each actor has it own mailbox
- actors exchange messages
- actors uses thread pool
- if actor receive message ask thread pool if there is free thread, if yes it uses it to proces all messages from mailbox
- thread pool can have for example: small number of threads in the night and grow during the day to proces users demand
- scheduler can send registered message periodically to actor to "wake it up" and to do some cyclic work; scheduler can also send message once at defined time
I like this separation between actors and threads. You can have many actors and only one-or-two threads.
What you think about it? Do you know actors model? :)
...but to write all of this I have to learn a lot about ChibiOS :)).
Arthur.
Look at that IRQ_STORM demo, there is a single thread in multiple instances, each instance has its own mailbox and all instances send messages each other, very similar to what you described.
It is meant as a stress test.
kermitas
Post by kermitas »
Giovanni wrote:Hi,
Yes, I am anaylzing IRQ_STORM demo right now.
In case of future questions - should I split them in to many simple-to-answer questions posted here, in "support" forum?
Arthur.
Focused questions are more efficiently answered of course.
sabdulqadir
Has thanked: 13 times
Been thanked: 4 times
Post by sabdulqadir »
utzig wrote:Hi,
Fabio Utzig
Have the structure changed? Could not find these in the current distribution. Or am i not looking at the correct stuff (https://github.com/ChibiOS/ChibiOS/tree/master/test) ?
AQ
It is \test\rt\source\test now.
