I am comming from Java/Scala world. I played a little bit with ChibiOS in C model. Now I wanted to try C++ as it is better for my object oriented brain.
How to start?
Where can I find some examples?
Is whole C ChibiOS world available from C++ oritented project?
Arthur.
How to start simple C++ project in Eclipse?
Re: How to start simple C++ project in Eclipse?
There are already C++ demos in ChibiOS, import them in Eclipse just like C demos. There are also several topics regarding C++ in the forum.
Giovanni wrote:There are already C++ demos in ChibiOS, import them in Eclipse just like C demos. There are also several topics regarding C++ in the forum.
Thank you for the answer.
Does C++ ChibiOS files are up to date so I can do everything that I can do using C ChibiOS files?
No, the C++ wrapper is quite old so it does not support all the new feature but from C++ you can call any C function without problems so nothing is really lost. You don't even need to use the wrapper and use ChibiOS as-is.
