compile error: CH_DBG_TRACE_MASK not defined Topic is solved
Moderator: tfAteba
orion
Has thanked: 4 times
Been thanked: 3 times
Post by orion »
Hi there,
Since last weekend, when trying to compile one of the AVR test or demo applications in the trunk branch, I get an error similar to the one below;
Compiling chsys.c
In file included from ../../../../os/rt/include/ch.h:91:0,
                 from ../../../../os/rt/src/chsys.c:36:
../../../../os/rt/include/chchecks.h:212:2: error: #error "CH_DBG_TRACE_MASK not defined in chconf.h"
Aṕparently, this is caused by a change in os/rt/include/chchecks.h, which no longer defines CH_DBG_TRACE_MASK, but throws an error instead if CH_DBG_TRACE_MASK isn't defined.
Checking the chconf.h file in the AVR apps' chconf.h file I see the line
#define CH_DBG_ENABLE_TRACE                 CH_DBG_TRACE_MASK_DISABLED
but no line defining CH_DBG_TRACE_MASK, whereas in some STM32 chconf.h file I see
#define CH_DBG_TRACE_MASK                   CH_DBG_TRACE_MASK_DISABLE
Does this means the AVR files need to be updated? Is the update just the insertion of the line above?
tfAteba
Has thanked: 91 times
Been thanked: 50 times
Re: compile error: CH_DBG_TRACE_MASK not defined
Post by tfAteba »
Hi there, first of all I want to apologize for my long silence,
Last week was so sad for me, I lost my father, so I was to the funeral.
But now I'm back, and I will look at you problem the week as soon as possible and give you a feed back.
Thank you for your Patience.
orion
Post by orion »
Theo,
Sorry to hear about your father. Take your time. This problem is not a pressing one. Cheers,
Hermano
I recently introduced stronger checks in RT, that message is the result of that change, just take a chconf.h from a working demo, make sure to set the proper values in it by taking them from the old one.
Better an error message than unaligned files in demos.
tfAteba
Post by tfAteba »
Hi all,
I have just update all configuration files to remove this compilation error.
