LwIP demo for Nucleo-144
Re: LwIP demo for Nucleo-144
There is an "unified" lwIP demo in trunk, those boards could be added easily but currently are not supported.
I have run this example on Nucleo-144, DHCP and ping is working correctly.
I have problem with HTTP server example thread, in netconn_new(NETCONN_TCP) I got timeout and WDG reset, other tasks has stop working. WDG has 1s period.
In function sys_arch_sem_wait(&apimsg->msg.conn->op_completed, 0); at line if (chSemWaitTimeoutS(*sem, tmo) != MSG_OK)
Could you explain why ? Is it LwIP misconfiguration ?
u32_t sys_arch_sem_wait(sys_sem_t *sem, u32_t timeout) {
systime_t tmo, start, remaining;
osalSysLock();
tmo = timeout > 0 ? MS2ST((systime_t)timeout) : TIME_INFINITE;
start = osalOsGetSystemTimeX();
if (chSemWaitTimeoutS(*sem, tmo) != MSG_OK) {
osalSysUnlock();
return SYS_ARCH_TIMEOUT;
remaining = osalOsGetSystemTimeX() - start;
osalSysUnlock();
return (u32_t)ST2MS(remaining);
}- Giovanni
You should check for stack overflow or other possible problems. I don't have enough info to tell why it is timing out.
My stack size is 0x8000.
Without debug functions, DHCP, ping works and led blink/WDG tasks correctly.
I have enabled DBG functions. Without LwIP initialization I got chSysHalt with reason S at this call stack
With enalbled LwIP: lwipInit(NULL); I got chSysHalt with reason S at this call stack
Why idle task has chSysHalt ?
chSysHalt
_dbg_check_enter_isr
VectorB0
<Exception frame>
_idle_thread
[_port_thread_start + 0x9]With enalbled LwIP: lwipInit(NULL); I got chSysHalt with reason S at this call stack
chSysHalt
_dbg_check_lock
chSysLock
chMtxLock
chHeapAllocAligned
chHeapAlloc
sys_sem_new
mem_init
lwip_init
tcpip_init
lwip_thread
[_port_thread_start + 0x9]Why idle task has chSysHalt ?
The reason is a string, look for what is after that "S".
Moving this topic in "bug reports".
For clarification:
In LWIP-FATFS-USB example I got chSysHalt SV#4 or SV#8 only in code compiled with IAR compiler, when http_server task is enabled, without this task ping works. Probably #pragma data_alignment is missing ?
The same code works correctly under GCC 6.3 compiled.
Tested with ChibiOS 17.6 and Nucleo-F429ZI
ps. Do you have plans to release makefile for IAR compiler. There is very nice IAR plugin for Eclipse.
How do you enable the debug options? in chconf.h or project options?
It would be nice to create a rules.ml for IAR but it is not high priority.
I enabled it in chconf.h file
Will only two Makefile files be dedicated for IAR? Like in GCC ?
Will the others remain unchanged?
$(CHIBIOS)/os/common/startup/ARMCMx/compilers/GCC/mk/startup_stm32f4xx.mk
$(CHIBIOS)/os/common/ports/ARMCMx/compilers/GCC/mk/port_v7m.mk
