Is there an example on how to use this? Thanks!
example about UART_DRIVER_EXT_FIELDS
josesimoes
- Has thanked: 43 times
- Been thanked: 23 times
Re: example about UART_DRIVER_EXT_FIELDS
I have no example right now, that macro is there in order to allow you to add fields to the UARTDriver structure, there are similar macros also in other drivers.
All you need to do is to define the macro in mcuconf.h and define more fields for the structure, use of those fields is up to you, consider that the structure is passed as pointer to callbacks, you may want to keep some additional state in there.
