Hi !
I'm trying to make project with my own board configuration. I want to have it outside Chibios tree just changing Chibios makefile variable to chibios path. Also I'v changed board.mk BOARDSRC path to path in my dir. But still sometimes chconf.h is found not from mine directory.
Building project and board configuration outside chibios tree Topic is solved
Re: Building project and board configuration outside chibios tree
Changing the board path is OK, I have not enough info about that chconf.h problem, it depends on your makefile.
I checked my folder and Makefile.
You can add a CONFDIR in your Makefile which points to the chconf.h, mcuconf.h and halconf.h.
In my case:
In my case:
CHIBIOS = ../../chibios
CONFDIR = ./conf- Giovanni
wurstnase wrote:Hi,
In my case:Code: Select all
CONFDIR = ./conf
Correct, this is true starting from version 18.2.0.
