STM32F7 - Switch from alternate function to normal pushpull
elagil
Has thanked: 8 times
Post by elagil »
Hello!
I have a problem when switching pin modes. First, a pin is used as normal output (push/pull) and I can switch it without problems.
Then, the pin is reused as a PWM output, so it has to be changed to an alternate function pin like this:
palSetLineMode(LINE_FPGA_INOUT0, PAL_MODE_ALTERNATE(2));
I get PWM output as expected. However, if I want to use the pin as normal push/pull output again, after using
palSetLineMode(LINE_FPGA_INOUT0, PAL_MODE_OUTPUT_PUSHPULL);
I cannot switch the pin manually anymore. Am I missing something? Why can it not be switched back to a normal push/pull pin again?
Thanks in advance,
Adrian
Re: STM32F7 - Switch from alternate function to normal pushpull
It should be possible to switch back, could you inspect the content of the related GPIO registers and see if the settings are those you would expect?
