[FEEDBACK] New repository
I am working on setting up a repository on a2hosting. Their offering has a limitation, only SSH access and no public read-only access to repos. It is possible to setup SSH tunnels for each user, developers would have to create an SSH key, probably not an huge issue, most people already uses SSH.
The main problem is with public access, I have thought to several possible solutions:
1) A public private SSH key (...), everybody interested could install this key and have read-only access to the repository.
2) Pushing the repository on a git repository on github using a cron job. Public access would be on github, basically what we already have but automatic. Korken already experimented with this so it is doable.
3) Pushing also on SF the current repository would become just a mirror, when it works...
4) Update the hosting to a VPS with Linux, it is not much cost that worries me but having to admin the server, it is not like I have much time to spare for this.
Other possible solutions? ideas?
Re: [FEEDBACK] New repository
Just a note. It is possible to have multiple SSH keys, I created a ~/.ssh/config like this and it works:
Host chibiforge.org chibifor.chibiforge.org
    HostName chibiforge.org
    IdentityFile ~/.ssh/id_rsa
    User chibifor
Host anonymous.chibiforge.org
    IdentityFile ~/.ssh/id_rsa_anonymous
    User chibifor
I can use both my personal key or the "anonymous" key with read-only access. There is no limit to the number of keys and aliases.
steved
Has thanked: 12 times
Been thanked: 138 times
Post by steved »
I'm sure this will be OK for those who are already convinced by ChibiOs. However it is a minor obstacle to newcomers wanting to get the code to evaluate. Having public downloads of each release outside the repository structure would most likely remove that obstacle (as long as the explanations are clear!!!!)
alex31
Has thanked: 57 times
Been thanked: 88 times
Post by alex31 »
Sorry for all the problems you meet for hosting our beloved ChibiOS ...
I think that for the vast majority of users, it will be sufficient and .... a necessity.
Young devs have only known git in their life, and most of old one like me who have began with rcs (i'm still to young to have known sccs :-) ), then svn then mercurial, then ... etc etc, have switched to git since years and don't even remember the most basic svn command ...
for me, you can keep svn if it's your preferred revision control system , as long as there is a git read only repository copy somewhere.
courage to face the difficulties to set up all this machinery.
apmorton
Been thanked: 17 times
Post by apmorton »
Have you considered Savannah? https://savannah.gnu.org/
We host free projects that run on free operating systems and without any proprietary software dependencies.
New projects are added on a case by case basis, and I don't know exactly how strict they are about licensing terms, but it may be worth inquiring.
Edit:
one more note - GitHub "supports" accessing git repos with SVN clients: https://help.github.com/articles/suppor ... n-clients/
I don't use SVN myself, so I can't tell you if this is something that is feasible, but in theory you may be able to host everything on the existing github organization, but continue to use your familiar SVN clients.
I know about the subversion feature of github, we use it for the community repository. It does not support some fundamental SVN features, like externals, that cannot be emulated over git.
I ported the repository over chibiforge.org. The checkout URL is:
svn+ssh://[email protected]/chibios/trunk
You need to install an ssh key in order access the repository (read only).
keys.zip
(1.92 KiB) Downloaded 803 times
In order to get write access developers will have to send me their PUBLIC SSH key. Note that it is possible to use multiple keys by configuring SSH, see my post above, I will write a guide about this later.
My first impression is that it is a lot faster than SF, I would appreciate feedback.
alex31
Post by alex31 »
Don't know if it's just problem of DNS propagation, but from france :
ping anonymous.chibiforge.org
ping: unknown host anonymous.chibiforge.org
Alexandre
I made an error, anonymous.chibiforge.org is an alias I created. Try svn+ssh://[email protected]/chibios/trunk
You should be able to ping chibiforge.org.
steved
Post by steved »
I can ping the site, but get "Connection Refused" when I try to connect.
I've used parts of these sites to set things up and test:
http://www.flickspin.com/en/software_de ... link_chaos
https://tortoisesvn.net/ssh_howto_logemann.html
https://kb.wisc.edu/education/page.php?id=45394
(Using TortoiseSVN on W7)
