Hello!
I am attempting to install ChibiStudio and receiving the following error when I run the ChibiStudio script:
"../ChibiStudio/ChibiStudio: line 11: $'\r': command not found"
Eclipse Mars loads but without the imported projects. Any ideas? Thank you.
ChibiStudio_Linux-Preview1.7 error
Re: ChibiStudio_Linux-Preview1.7 error
Verify if the shell script contains CRLF as EOL, it is possible that is causing problems.
Ahh, yes thank you. I opened the script with vim and removed three instances of ^M. That resolved the script error.
The demo projects are still not automatically loading on start-up. I have been able to find them manually.
The problem are hardcoded paths /home/giovanni, cannot avoid this...
