Serial driver Transmission End Topic is solved
alexblack
Been thanked: 33 times
Post by alexblack »
Hi.
I used ChibiOS 17.6.x and after updating to the latest version I was found that changes in SERIAL drivers is affect to my program.
I have function to send 1 (ONE) byte over serial driver is SPI mode.
 * \brief       Setting the given value to potenciometer
 * \param[in]   value - given value
void PGA_Class::set_value(char value) {
  // Start the driver
  static const SerialConfig pga_serial_cfg = {
  4500000,
  0,
  USART_CR2_MSBFIRST | USART_CR2_CLKEN | USART_CR2_LBCL, // | USART_CR2_CPHA | USART_CR2_CPOL
  0
  sdStart(&PGA_SERIAL_DRIVER, &pga_serial_cfg);
  // RX not used
  PGA_SERIAL_DRIVER.usart->CR1 &= ~USART_CR1_RE;
  // Register event listener to receive USART events
  event_listener_t el_sd;
  chEvtRegisterMask(chnGetEventSource(&PGA_SERIAL_DRIVER), &el_sd, 128);
  // Accert the CS line
  palClearPad(cs->port, cs->pin_n);
  // write to register
  sdPut(&PGA_SERIAL_DRIVER, value);
  // wait the end of transmission
  for (;;) {
    eventmask_t m = chEvtWaitOneTimeout(128, MS2ST(100));
    if (m == 0) break;
    // event of the UART
    eventflags_t flags = chEvtGetAndClearFlags(&el_sd);
    if (flags & CHN_TRANSMISSION_END)
      break;
  // Release the CS
  palSetPad(cs->port, cs->pin_n);
  // Unregiister
  chEvtUnregister(chnGetEventSource(&PGA_SERIAL_DRIVER), &el_sd);
  // Stop the driver
  sdStop(&PGA_SERIAL_DRIVER);
When I used before the function was success to wait end of transmission, but now it exit with timeout.
I looking to the change history and found that there was this changes:
What was the need to really change this behavior?
Re: Serial driver Transmission End
The idea is that the flag should be raised only if the TCIE interrupt is enabled.
TCIE is enabled when a transmission is started and cleared when it is completed and the event has been triggered.
alexblack
Post by alexblack »
In my case (one byte transsmission) the TC flag is raised before the TXE flag is served and thus do not generate TC interrupt.
I tried send 2 bytes - new code work well. But what to do with one byte. I need to wait the end of transmission to deactivate the CS line.
You could try, in the LLD, to set USART_CR1_TCIE in those notifyX() functions and remove it from serve_interrupt(), this should fix that specific problem.
static void notify5(io_queue_t *qp) {
  (void)qp;
  UART5->CR1 |= USART_CR1_TXEIE | USART_CR1_TCIE;
Let me know how this goes, I would make the change in repository too.
alexblack
Post by alexblack »
I thinking that there will be errornous TC events when there are the gaps between the chars if the baud rate is fast enough or if the system has large load.
alexblack
Post by alexblack »
I tried your suggestion to notifyX function and it works.
The DEBUG OUT function is:
PGA: > set value 127
PGA: > m = 0080
PGA: > flags = 0018
PGA: > end
Was before:
PGA: > m = 0080
PGA: > flags = 0008
PGA: > m = 0000
PGA: > timeout
Moving this in "bug reports", it is definitely a problem in the driver.
Fixed as bug #958.
