Ethernet PTP time stamp status register bits Topic is solved
Raul
Has thanked: 3 times
Post by Raul »
The following should be applicable to ST family (os/common/ext/ST/) with TSTTR & TSSO defined.
Assuming 17.6.3, changes should be:
#define ETH_PTPTSSR_TSTTR    0x00000002U  /* Time stamp target time reached */
#define ETH_PTPTSSR_TSSO     0x00000001U  /* Time stamp seconds overflow */
In 18.2.1 the position offsets should change to:
#define ETH_PTPTSSR_TSTTR_Pos                        (1U)
#define ETH_PTPTSSR_TSSO_Pos                         (0U)
Raul
Re: Ethernet PTP time stamp status register bits
Those errors should be reported to ST.
Raul
Post by Raul »
Ok,
Out of curiosity, where are the ST CMSIS headers downloaded from?
Raul
Those are included in the various CubeMX packages.
