Suppress *.lst files?
steved
Has thanked: 12 times
Been thanked: 138 times
Post by steved »
The build process generates a *.lst file for each source file; these seem to be of little or no use (at least to people like me). Is there an easy way to suppress them? (Using ChibiStudio if relevant).
Also, is there an easy way to generate an assembly language listing as part of the compile process? (I know its possible to upload to the target and do a disassembly, but right now I don't have the right target hardware!)
Re: Suppress *.lst files?
A ch.list file is generated, it is the listing of the whole program.
steved
Post by steved »
Giovanni wrote:Hi,
Thanks - I must have looked right past this one.
But have you noticed that the source code lines aren't always correct? (It's evident in that thread discussing use of 'volatile')
It is likely because optimizations, it is impossible to associate 1 to 1 source to asm (inlining, unrolling, reordering, deleting, etc).
