HAL os-less & ISR execution issue Topic is solved
eblot
Post by eblot »
I'm trying to use the HAL (os-less) mode for a PoC project (STM32L0, NUCLEO64_L053R8 and NUCLEO32_L011K4).
I've enabled one serial port (SD2) for debugging traces, one timer (TIM2), and a couple of GPIO.
STM32 uses HSI16 as the main clock source. I can observe the (scaled) clock on a GPIO (using MCO)
I'm running TIM2 with HAL_GPT in continuous mode, with a callback (4MHz, ARR: 0xFFFF).
The callback is configured to toggle a GPIO on each call.
I can observe that the callback never gets called when the main() function is running a busy loop (something like for(;;) {}).
If I add some call to osalThreadSleepMilliseconds() in this loop, the callback is called.
I would have expected that the "main" (unique) thread would get preempted by the TIM2 ISR, but it seems it is not, so I guess I missed an important point somewhere (configuration)? I'm pretty sure it is not related to TIM2, as I can observe that the SD2 traces do not get output if a busy loop is called right after chprintf() has been called - I guess same symptom, ISR is not executed.
There is something critical I did not get about ChibiOS & OS-less mode it seems. I would have expected the ISR to execute even if the main() function was running a busy loop.
Any clue?
I tried to locate some demo about os-less environments, but I failed to find a matching example.
I've read that osalThreadSleepMilliseconds() uses a virtual timer, which seems to be documented as a part of the RT subsystem, so I got even more confused :-)
Unrelated question: is the IRQ priority level (order, boundaries, ..) documented somewhere?
Re: HAL os-less & ISR execution issue
Do you enable interrupts in your main() ? the main function is entered with interrupts disabled.
eblot
Post by eblot »
I call
osalSysEnable();
once HW configuration in complete (before the busy loop), which call __enable_irq() if I'm not mistaken.
I just give a tried and force OSAL_ST_MODE == OSAL_ST_MODE_NONE and it seems the ISR handler is called as expected. I'm not sure why.
As this setting is not part of the osalconf.h, I never tried to changed it up to now - and I may be on the wrong way here.
I guess that w/o it, I will not be able to call functions such as osalThreadSleepMilliseconds() as there is no tick to wake the thread up.
eblot
Post by eblot »
If I use the following kludge in the busy loop:
   for(;;) {
      __enable_irq();
      __disable_irq();
the TIM2 ISR handler runs.
If I only move the IRQ enablement before the loop:
    __enable_irq();
   for(;;) {
the TIM2 ISR does not get called anymore.
I guess that "something" fails to restore the IRQ, but I do not know (yet) what.
The only callback I used is dedicated to TIM2 and is rather simple:
static void
_ow_gpt_cb(GPTDriver * gptp) {
   (void)gptp;
   _ow_ge.ge_ticks += 1;
   palTogglePad(LED1_GPIO_PORT, LED1_GPIO_PIN);
static const GPTConfig _GPT2_CONFIG = {
   .frequency = STM32_HSI16CLK >> 2U,
   .callback = _ow_gpt_cb,
struct ow_gpt_engine {
   volatile uint32_t ge_ticks;
struct ow_gpt_engine _ow_ge;
eblot
Post by eblot »
From ChibiOS_18.2.1/os/hal/osal/os-less/ARMCMx/osal.h
 * @brief   Enters a critical zone from ISR context.
 * @note    This function cannot be used for reentrant critical zones.
 * @special
static inline void osalSysLockFromISR(void) {
#if CORTEX_MODEL == 0
  __disable_irq();
#else
  __set_BASEPRI(OSAL_IRQ_MAXIMUM_PRIORITY);
 * @brief   Leaves a critical zone from ISR context.
 * @special
static inline void osalSysUnlockFromISR(void) {
osalSysUnlockFromISR()
to be symetrical with
osalSysLockFromISR()
and call
__enable_irq()
Is it on purpose?
It is the error I think, modify as follow:
  __enable_irq();
#else
  __set_BASEPRI(0);
Moving this topic in bug reports, it will be fixed in next release.
eblot
Post by eblot »
I changed the function with this code (when I posted the question actually), and it indeed fixed the problem, but I was not sure it was the root cause.
Thanks for your help,
Manu.
While seeking the code, I noticed a couple of typos in the comments, unrelated to this issue.
I'm not sure to report this (pull request?), sorry for this off-topic add-on:
* os/hal/ports/STM32/LLD/TIMv1/hal_st_lld.c@248:
 * @brief   TIM2 interrupt handler.
-> free running counter may be different than TIM2
* os/common/ext/ST/STM32L0xx/stm32*.h
#define RCC_CFGR_MCO_PRE_2                  RCC_CFGR_MCOPRE_DIV2        /*!< MCO is divided by 1 */
#define RCC_CFGR_MCO_PRE_4                  RCC_CFGR_MCOPRE_DIV4        /*!< MCO is divided by 1 */
#define RCC_CFGR_MCO_PRE_8                  RCC_CFGR_MCOPRE_DIV8        /*!< MCO is divided by 1 */
#define RCC_CFGR_MCO_PRE_16                 RCC_CFGR_MCOPRE_DIV16       /*!< MCO is divided by 1 */
-> divider value comment is not accurate.
Fixed as bug #987.
