chprintf and 64-bit numbers
tsichevski
Has thanked: 2 times
Been thanked: 5 times
Post by tsichevski »
Is it possible to use 64-bit values with chprintf?
Regards,
Vladimir
Re: chprintf and 64-bit numbers
Currently not, it is not meant for a full printf() replacement.
tsichevski
If I add the 64-bit support, would it be appropriate to add it to ChibiOS somehow?
Regards,
Vladimir
It depends on code size increase, it is just an utility and it is meant to run also on 8 bits cores, some compilers don't have 64 bits types at all.
steved
Has thanked: 12 times
Been thanked: 138 times
Post by steved »
Giovanni wrote:Hi,
Maybe enable/disable dependent on 64-bit type support (c99 standard or later).
Or have a default setting which is processor dependent, with an option to override (default disable on 8-bit, F0; enable on F4, F7, H7 for example).
Or both.
tsichevski
Giovanni wrote:Hi,
In any case it should be coded with conditionals, like the following:
#ifdef CHPRINTF_USE_LONGLONG
#endif // CHPRINTF_USE_LONGLONG
A conditional would be fine, note there are other conditionals, follow that pattern.
tsichevski
Done. There can I send the patched files? This forum does not allow to attach .c files :(
Regards,
Vladimir
You can attach zip/7z files.
tsichevski
The modified chprintf.c attached.
Also, you'll need to add something like
 * @brief   Long long type support.
#if !defined(CHPRINTF_USE_LONGLONG) || defined(__DOXYGEN__)
#define CHPRINTF_USE_LONGLONG          TRUE
to the chprintf.h
Regards,
Vladimir
chprintf.c.zip
(2.96 KiB) Downloaded 548 times
