Korken,
What's the reason for declaring most of the classes final? IMHO it takes out the elegancy from interfacing ChibiOS with C++. For example, with the old wrapper you could derive a class from BaseStaticThread, define a main() member function and call any thread-related function implicitly against the this pointer. Now you have to store a reference to the Thread object and prefix all calls with that member. For now I don't see a reason why these classes need to be final. Without that you would still have the freedom to choose between inheritance or referencing.
Thanks, Szabi
C++ wrappers
Re: C++ wrappers
szekelyisz wrote:Korken,
Thanks, Szabi
This comes from the changes made in the beginning of these new wrappers, and I had the same question as you.
But helmut had good points about it: viewtopic.php?f=3&t=3287&start=50#p27048
Also, your should really not be using virtual inheritance any more. There is a really good talk on YouTube from one of the latest C++ conferences, I will try to find it.
Use a std::variant for all supported types instead or CRTP, I have yet to find a case where I really needed virtual inheritance in embedded.
However, if a use case is found that cannot be within this style, please provide it and we can look at updating the interface.
rbarreiros
Re: C++ wrappers
I'm having a problem with the latest trunk, I have a class and a callback typedef like this:
I already have os/various/syscalls.c and syscalls_cpp.cpp being compiled in the Makefile.
I skipped most of the obvious stuff, of course the pointer is init with NULL, there's methods to set it, etc, but whenever I call the callback in the c++ method, I get:
using OSX
Any hint of what I must be doing wrong ?
typedef void (*MyCbFunction)(int);
class MyClass
public:
MyClass();
void somefunc(void);
private:
MyCbFunction _cb;
MyClass::somefunc(void)
// Do stuff, have some pointer func point to _cb etc
if(_cb != NULL)
_cb(10);
/usr/local/Cellar/arm-none-eabi-gcc/20180627/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/libg.a(lib_a-abort.o): In function `abort':
abort.c:(.text.abort+0xa): undefined reference to `_exit'
/usr/local/Cellar/arm-none-eabi-gcc/20180627/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/libg.a(lib_a-signalr.o): In function `_kill_r':
signalr.c:(.text._kill_r+0x10): undefined reference to `_kill'
/usr/local/Cellar/arm-none-eabi-gcc/20180627/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/libg.a(lib_a-signalr.o): In function `_getpid_r':
signalr.c:(.text._getpid_r+0x0): undefined reference to `_getpid'
using OSX
Using built-in specs.
COLLECT_GCC=arm-none-eabi-gcc
COLLECT_LTO_WRAPPER=/usr/local/Cellar/arm-none-eabi-gcc/20180627/bin/../lib/gcc/arm-none-eabi/7.3.1/lto-wrapper
Target: arm-none-eabi
Configured with: /Users/build/work/GCC-7-build/src/gcc/configure --target=arm-none-eabi --prefix=/Users/build/work/GCC-7-build/install-native --libexecdir=/Users/build/work/GCC-7-build/install-native/lib --infodir=/Users/build/work/GCC-7-build/install-native/share/doc/gcc-arm-none-eabi/info --mandir=/Users/build/work/GCC-7-build/install-native/share/doc/gcc-arm-none-eabi/man --htmldir=/Users/build/work/GCC-7-build/install-native/share/doc/gcc-arm-none-eabi/html --pdfdir=/Users/build/work/GCC-7-build/install-native/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --enable-plugins --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-newlib --with-headers=yes --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/Users/build/work/GCC-7-build/install-native/arm-none-eabi --build=x86_64-apple-darwin10 --host=x86_64-apple-darwin10 --with-gmp=/Users/build/work/GCC-7-build/build-native/host-libs/usr --with-mpfr=/Users/build/work/GCC-7-build/build-native/host-libs/usr --with-mpc=/Users/build/work/GCC-7-build/build-native/host-libs/usr --with-isl=/Users/build/work/GCC-7-build/build-native/host-libs/usr --with-libelf=/Users/build/work/GCC-7-build/build-native/host-libs/usr --with-host-libstdcxx='-static-libgcc -Wl,-lstdc++ -lm' --with-pkgversion='GNU Tools for Arm Embedded Processors 7-2018-q2-update' --with-multilib-list=rmprofile
Thread model: single
gcc version 7.3.1 20180622 (release) [ARM/embedded-7-branch revision 261907] (GNU Tools for Arm Embedded Processors 7-2018-q2-update)
Re: C++ wrappers
Strange, those are in syscalls_cpp.cpp, are you sure the module is linked with the application? try disabling the linker garbage collection and/or LTO.
rbarreiros
Re: C++ wrappers
It linked with -fno-lto, but --no-gc-sections (with or without) made no changes.
Note that I had to add syscalls.c to the make file, and of course, syscalls_cpp.cpp is added from chcpp.mk
