Time measurement between two ISRs, general idea?
horstman
Post by horstman »
Hello!
I would like to stop the time (in seconds) with a timer between two differents ISRs.
The first ISR should start, the second should stop the timer.
Could You give me a general idea, which approach would be the best for such a problem?
Thank You!
Horst
Re: Time measurement between two ISRs, general idea?
If you need to measure time then use the TM API (Time Measurement), no need to use timers and it is clock cycle accurate.
horstman
Post by horstman »
all right, I will try that out, thank You!
I wonder if You could help me with another issue. (sorry, I'm still a newbie to ChibiOS...)
I would like to implement/enable external interrupt on a button (+ "ISR"/callback-function) with palSetPadCallbackI()/PAL Driver ..., but I am not quite sure which steps are necessary for this. Would it be possible for You to provide a minimal example for this or to tell me, where I can find one? Or would You rather suggest another, better approach?
Thank You very much!
In /testhal/STM32/multi/PAL there is the example you need.
