External dependencies for Makefile
dflogeras
Has thanked: 8 times
Been thanked: 22 times
Post by dflogeras »
Hi all,
I frequently set up my Chibi projects to depend on my own common libraries for sharing code between different projects. They are built separately and installed into a dir where I point the Chibi build system. So I typically have something like this in my Makefile:
ULIBDIR = some/path/where/installed
ULIBS = -lfoo -lbar
However, during development sometimes I'll recompile libfoo.a and rebuild my Chibi project afterwards. If I haven't made any changes to the Chibi project itself, it thinks it is already up to date. Is there a way to set up the Chibi makefile to have a proper dependency on the libfoo.a timestamp so it knows to rebuild when the underlying libraries have been modified?
Dave
Re: External dependencies for Makefile
Not sure how to implement that, there is not a direct path to library files, even the library name is not the real file name.
dflogeras
Post by dflogeras »
So the nice folks in #gnu IRC channel pointed me in the right direction. In case anyone else needs, you can easily make the project elf target depend on an arbitrary file's time. The trick is making sure you put it _after_ the include rules.mk which defines the elf target.
RULESPATH = $(CHIBIOS)/os/common/startup/ARMCMx/compilers/GCC
include $(RULESPATH)/rules.mk
# Relink whenever a static library is updated
$(BUILDDIR)/$(PROJECT).elf: $(ULIBDIR)/*.a
The use of $(ULIBDIR) may need to be tweaked in other situations, since if it is a list, and not all directories contain .a files, it will fail. YMMV
