Invoking: GCC C Compiler
C:/ChibiStudio/chibios191/test/rt/source/test/rt_test_root.c:42:10: fatal error: hal.h: No such file or directory
#include "hal.h"
gcc -O2 -g -Wall -c -fmessage-length=0 -MMD -MP -MF"test/rt/source/test/rt_test_sequence_002.d" -MT"test/rt/source/test/rt_test_sequence_002.d" -o "test/rt/source/test/rt_test_sequence_002.o" "C:/ChibiStudio/chibios191/test/rt/source/test/rt_test_sequence_002.c"
compilation terminated.Should this demo be expected to work out-of-the-box or am I missing something? I am using ChibiStudio 20.7 and ChibiOS 19.1.0. I have verified that the CHIBIOS directory in the makefile is correct. I also have MinGW installed and C:/MinGW/bin added to my PATH. The Eclipse toolchain settings are "MinGW GCC" and "Gnu Make Builder".
I should add that I am able to build and run STM32 demos with no issues.
Any hints?
