How to correctly handle USB_CDC communication? Topic is solved
arbulgazar
Post by arbulgazar »
Greetings! I am developing a project based on STM32F406Discovery board which boils down to communication via USB with the application on the PC (connected via mico-usb to stm board).
For that, I have 2 threads - for reading and writing. Writing thread is supposed to be spamming USB with a status messages. Reading thread is supposed to read occasional commands from main PC. Now the problem I have is that reading is sometimes not working and I don't have enough knowledge to understand the reason. I suspect that this is due to the spamming of the write-thread. Essentially it is fine to lose some status-spam messages but it is crucial to process all the incoming messages. I am not sure if I did everything correctly on my side, or is that the application on the main PC side to blame. Should I use interrupts for when there is reading available on the bus? What should I look for to make this fail-safe?
As a project startup, I used demo provided in chibios_trunk\testhal\STM32\multi\USB_CDC with ChibiOS 18.2.
Here is a narrowed-down code that should give a good understanding of how I do this.
THD_FUNCTION(readThrFunction, arg)
  (void) arg;
  chRegSetThreadName("Read thread");
  char readBuffer[128];
  event_listener_t usbData;
  eventflags_t flags;
  int bytesRead = 0;
  chEvtRegisterMask((event_source_t *)chnGetEventSource(&PORTAB_SDU1), &usbData, EVENT_MASK(1));
  while (TRUE)
    chEvtWaitAll(EVENT_MASK(1));
    flags = chEvtGetAndClearFlags(&usbData);
    if (flags & CHN_INPUT_AVAILABLE)
      bytesRead = chnReadTimeout(&PORTAB_SDU1, readBuffer, 64, 1000);
      doStuff();
THD_FUNCTION(writeThrFunction, arg)
  (void) arg;
  chRegSetThreadName("write thread");
  char payloadBuffer[64];
  int payloadLength = 0;
  while (TRUE)
    getSomeUsefullStuff(...);
    chnWriteTimeout(&PORTAB_SDU1, payloadBuffer, payloadLength, 10);
    chThdSleepMilliseconds(10);
static THD_WORKING_AREA(readThrWA, 1024);
static THD_WORKING_AREA(writeThrWA, 1024);
main()
  ... // initialization stuff
  chThdCreateStatic(readThrWA, sizeof(readThrWA), HIGHPRIO, readThrFunction, NULL);
  chThdCreateStatic(writeThrWA, sizeof(writeThrWA), NORMALPRIO, writeThrFunction, NULL);
  while (true) {
Re: How to correctly handle USB_CDC communication?
Try the "USB RAW" demo, it could be closer to what you need. It uses USB directly without the buffering (that you don't need probably).
arbulgazar
Hi! Thanks for answering. I need serial over USB though. What is the disadvantage of having a buffer in my case?
In both cases it is a CDC device, it depends if you want buffered read/write or not. If it is unbuffered then read/write return when the operation is complete, not immediately.
Just look at the demo.
