RTC driver and EXTI->PR Topic is solved
vrollei
Been thanked: 26 times
Post by vrollei »
What is the best place to define correct EXTI->PRx register for RTC driver / alarm line?
For example:
STM32L1 uses EXTI->PR register
and
STM32L4 uses EXTI->PR1
RTC and EXTI driver in version 19.1 support only EXTI->PR1 register
Thanks in advance!
Re: RTC driver and EXTI->PR
The PAL driver does it this way:
/* Driver local definitions.                                                 */
/* Handling a difference in ST headers.*/
#if defined(STM32L4XX) || defined(STM32L4XXP)
#define EMR     EMR1
#define IMR     IMR1
#define PR      PR1
#define RTSR    RTSR1
#define FTSR    FTSR1
The same is also in stm32_exti.h:
/* Handling differences in ST headers.*/
#if !defined(STM32L4XX) && !defined(STM32L4XXP)
#define EMR1    EMR
#define IMR1    IMR
#define PR1     PR
#define RTSR1   RTSR
#define FTSR1   FTSR
Probably it should only be in EXTI and other drivers should use it. I am looking into this.
Fixed as bug #1022.
It should be fine in trunk and 19.1.x now, could you check?
vrollei
Post by vrollei »
thanks a lot!
I will check it.
vrollei
Post by vrollei »
it seems STM32L1xx/stm32_registry.h does not contain:
#define STM32_RTC_TAMP_STAMP_HANDLER
#define STM32_RTC_WKUP_HANDLER
#define STM32_RTC_ALARM_HANDLER
#define STM32_RTC_TAMP_STAMP_NUMBER
#define STM32_RTC_WKUP_NUMBER
#define STM32_RTC_ALARM_NUMBER
#define STM32_RTC_ALARM_EXTI
#define STM32_RTC_TAMP_STAMP_EXTI
#define STM32_RTC_WKUP_EXTI
#define STM32_RTC_IRQ_ENABLE()
vrollei
Post by vrollei »
#define STM32_RTC_TAMP_STAMP_HANDLER        Vector48
#define STM32_RTC_WKUP_HANDLER              Vector4C
#define STM32_RTC_ALARM_HANDLER             VectorE4
#define STM32_RTC_TAMP_STAMP_NUMBER         3
#define STM32_RTC_WKUP_NUMBER               1
#define STM32_RTC_ALARM_NUMBER              2
#define STM32_RTC_ALARM_EXTI                17
#define STM32_RTC_TAMP_STAMP_EXTI           19
#define STM32_RTC_WKUP_EXTI                 20
Fixed as bug #1023.
There were some other things missing too.
