i2c DMA change STM32F4
chrisjensen
Post by chrisjensen »
Hey all,
I am trying to use the pins 7 and 8 of port B on the STM32F4DISCOVERY for i2c and can't seem to make it work. I have followed the port instructions, and have re-checked my code several times, and I can't get it to work. The demo code works with GPIOB PIN6 and GPIOB PIN9, I have made my own custom boards.h, modifying only the parts that were relevant as shown below.
#define GPIOB_SCL               6
#define GPIOB_SDA               9
 * Port B setup.
 * All input with pull-up except:
 * PB3  - GPIOB_SWO             (alternate 0).
 * PB6  - GPIOB_SCL             (alternate 4).
 * PB9  - GPIOB_SDA             (alternate 4).
#define VAL_GPIOB_MODER             (PIN_MODE_INPUT(0) |                    \
                                     PIN_MODE_INPUT(1) |                    \
                                     PIN_MODE_INPUT(2) |                    \
                                     PIN_MODE_ALTERNATE(GPIOB_SWO) |        \
                                     PIN_MODE_INPUT(4) |                    \
                                     PIN_MODE_INPUT(5) |                    \
                                     PIN_MODE_ALTERNATE(GPIOB_SCL) |        \
                                     PIN_MODE_INPUT(7) |                    \
                                     PIN_MODE_INPUT(8) |                    \
                                     PIN_MODE_ALTERNATE(GPIOB_SDA) |        \
                                     PIN_MODE_INPUT(10) |                   \
                                     PIN_MODE_INPUT(11) |                   \
                                     PIN_MODE_INPUT(12) |                   \
                                     PIN_MODE_INPUT(13) |                   \
                                     PIN_MODE_INPUT(14) |                   \
                                     PIN_MODE_INPUT(15))
#define VAL_GPIOB_OTYPER            (PIN_OTYPE_OPENDRAIN(GPIOB_SCL) |       \
                                     PIN_OTYPE_OPENDRAIN(GPIOB_SDA))
#define VAL_GPIOB_OSPEEDR           0xFFFFFFFF
#define VAL_GPIOB_PUPDR             (PIN_PUDR_PULLUP(0) |                   \
                                     PIN_PUDR_PULLUP(1) |                   \
                                     PIN_PUDR_PULLUP(2) |                   \
                                     PIN_PUDR_FLOATING(GPIOB_SWO) |         \
                                     PIN_PUDR_PULLUP(4) |                   \
                                     PIN_PUDR_PULLUP(5) |                   \
                                     PIN_PUDR_FLOATING(GPIOB_SCL) |         \
                                     PIN_PUDR_PULLUP(7) |                   \
                                     PIN_PUDR_PULLUP(8) |                   \
                                     PIN_PUDR_FLOATING(GPIOB_SDA) |         \
                                     PIN_PUDR_PULLUP(10) |                  \
                                     PIN_PUDR_PULLUP(11) |                  \
                                     PIN_PUDR_PULLUP(12) |                  \
                                     PIN_PUDR_PULLUP(13) |                  \
                                     PIN_PUDR_PULLUP(14) |                  \
                                     PIN_PUDR_PULLUP(15))
#define VAL_GPIOB_ODR               0xFFFFFFFF
#define VAL_GPIOB_AFRL              (PIN_AFIO_AF(GPIOB_SWO, 0) |            \
                                     PIN_AFIO_AF(GPIOB_SCL, 4))
#define VAL_GPIOB_AFRH              (PIN_AFIO_AF(GPIOB_SDA, 4))
to this:
#define GPIOB_SCL               8
#define GPIOB_SDA               7
 * Port B setup.
 * PB8  - GPIOB_SCL             (alternate 4).
 * PB7  - GPIOB_SDA             (alternate 4).
                                     PIN_MODE_INPUT(6) |                    \
                                     PIN_MODE_INPUT(9) |                    \
                                     PIN_MODE_INPUT(15))
                                     PIN_PUDR_PULLUP(6) |                   \
                                     PIN_PUDR_PULLUP(9) |                   \
#define VAL_GPIOB_AFRH              (PIN_AFIO_AF(GPIOB_SCL, 4))
I have also redefined my DMA in the mcuconfig.h from this:
#define STM32_I2C_USE_I2C1                  TRUE
#define STM32_I2C_USE_I2C2                  FALSE
#define STM32_I2C_USE_I2C3                  FALSE
#define STM32_I2C_I2C1_RX_DMA_STREAM        STM32_DMA_STREAM_ID(1, 0)
#define STM32_I2C_I2C1_TX_DMA_STREAM        STM32_DMA_STREAM_ID(1, 6)
to this:
#define STM32_I2C_I2C1_RX_DMA_STREAM        STM32_DMA_STREAM_ID(1, 5)
#define STM32_I2C_I2C1_TX_DMA_STREAM        STM32_DMA_STREAM_ID(1, 7)
I am at a loss, I have spent the last 3 days trying to make this work.
-Christopher
Re: i2c DMA change STM32F4
Hi Christopher,
Probably I found an error that could cause this problem, in hal_lld.h in line 321 could you try to change
#define STM32_I2C1_TX_DMA_CHN 0x10000000
in
#define STM32_I2C1_TX_DMA_CHN 0x11000000
Apparently one of the I2C alternate DMA channels is wrongly defined. If this is confirmed I will open a ticket, thanks.
chrisjensen
I ended up doing a hardware mod because of time constraints. It is for my EE senior project which is due today, so I will try this when I get some time and let you know the details.
