hal_st_lld override implementation
vrollei
Been thanked: 26 times
Post by vrollei »
what is the best way to override hal_st_lld implementation?
Re: hal_st_lld override implementation
Currently there is no clean mode if you are using HAL...
Proceed as follow:
1) Edit osal.h and make it define OSAL_ST_MODE_NONE, this disables the ST driver.
2) Define PORT_USE_ALT_TIMER=1 in your makefile and provide a chcore_timer_alt.h file with your own implementation.
I'll do something about point 1 next. Point 2 is already fine and working as intended.
Probably it would be a good idea to overhaul the ST driver, I may need more comparators for a new kernel safety feature soon (thread watchdogs).
vrollei
Post by vrollei »
Thanks for reply!
I mean overriding only low level implementation: hal_st_lld.h/hal_st_lld.c.
I have RTC based ST implementation, but it is very annoying to edit hal_st_lld.h/hal_st_lld.c every time....
You could just make your own .mk file to import from your Makefile, place your LLDs into another directory.
vrollei
Post by vrollei »
with modified make file it would be difficult to change project config: change ST timer....
Is it possible to use STM32_ST_USE_TIMER == 0 macro to switch between implementations?
Or maybe you can add ST based on RTC implementation to STM32 hal_st_lld?
