USART timeout_cb
USART timeout_cb
I am trying to enable timeout_cb for Modbus communication timeout handling, but there is no call of timeout_cb
timeout_cb and timeout values are set in config
and RTOEN and RTOIE set to 1
How to enable timeout_cb?
Thanks!
Thanks!
Re: USART timeout_cb
You need also to set the timeout field in the configuration structure, it initializes the RTOR register.
Edit: OK, great...
Edit: OK, great...
Is it possible to implement something like this:
1. Start receive
2. Wait first byte and if there is no one for some period T, then it is timeout.
3. If first byte received then use timeout_cb to determine end of frame.
1. Start receive
You can do that using a virtual timer, start the receive (of one byte) and the timer at same time within a critical section.
yes,
I tried to implement it using rxchar_cb, vt and uartStartReceive with rx buffer size 256 bytes (it is maximum Modbus frame size).
It would not work as I understand. rxchar_cb will not be called on char received.
Right?
EDIT: It is critical not to restart usart receive, otherwise there is chance to miss char....
Right?
rxchar_cb is there to "consume" incoming unexpected data, it is better if you start an explicit 1 byte receive then start a receive for the rest.
Ideally you should never have an rxchar_cb.
size_t n = 1;
if (usartReceiveTimeout(usartDriver, &n, buffer, TIME_MS2I(MODBUS_RX_TIMEOUT_MS)) == MSG_OK) {
usartStartReceive(usartDriver, MODBUS_BUFFER_SIZE - 1, buffer + 1);
chSemWait(rxtimeout_sem);
n = MODBUS_BUFFER_SIZE - usartStopReceive(usartDriver);
} else {
RX_TIMEOUT;
Does usartStopReceive count char from usartReceiveTimeout?
one more thing:
whithout chThdSleepMilliseconds n will be 1
It seems I set wrong timeout value...
chThdSleepMilliseconds(500);
n = MODBUS_BUFFER_SIZE - usartStopReceive(usartDriver);whithout chThdSleepMilliseconds n will be 1
usartStopReceive() returns the number of frames still not received in the current receive operation.
I suggest you implement your protocol as a state machine and use (UART and timers) callbacks for transitions. The driver has been designed with that scenario in mind.
