how to send/receive struct with mailbox
taufiqwidi
Post by taufiqwidi »
hello,
how to send/receive struct with mailbox? i know this question have been asked before but it was like 3 years ago. i have follow this code in the forum that 3 years old (http://www.chibios.com/forum/viewtopic.php?t=3270). but the receiving thread doesnt receive correct data from struct (like it is not point to the right struct or memory pool). i get notifier C++ library made by someone in this forum (https://github.com/trsaunders/Chibios-Notifications) (but it was like 7 years old) and it seems not to work anymore. answers are very apperciated cause i cant get mailbox to work (receiving the message actually).
thank you,
taufiqwidi
Re: how to send/receive struct with mailbox
See "Object FIFOs" in OSLIB, it does that for you.
taufiqwidi
Giovanni wrote:Hi,
hello,
thanks giovanni for your answer. am i use this object fifo with malibox? i cannot find any wikis about object fifo so far. (if i am not mistaken). and i have no clue about it.
thank you,
taufiqwidi
Object FIFO is a combo of a mailbox and a memory pool.
On the sender side:
1) You TAKE an object from the pool.
2) You SEND an object through the mailbox.
On the receiver side:
3) You RECEIVE an object from the mailbox.
4) You RETURN the object to the pool.
taufiqwidi
okay i see. thanks Giovanni for your answer. i will try that.
taufiqwidi
taufiqwidi
hello,
sorry Giovanni if i bothering you again and maybe this is the dumb question. is there any examples of "Object FIFO" usage? because i cant find any example..
thank you..
