Mailboxes and queues examples?
sntnjrg
Has thanked: 18 times
Been thanked: 3 times
Re: Mailboxes and queues examples?
Post by sntnjrg »
Following the IRQ_STORM example, I have written the following code:
#define MAILBOX_MSG_SIZE                    64
static mailbox_t mb;
static msg_t mb_msg[MAILBOX_MSG_SIZE];
static THD_WORKING_AREA(waThdBlinker, 128);
static THD_FUNCTION(ThdBlinker, arg) {
  (void)arg;
  chRegSetThreadName("Blinker");
  static msg_t msgp[MAILBOX_MSG_SIZE];
  while (true) {
    switch (chMBFetchTimeout(&mb, msgp, TIME_INFINITE)) {
    case MSG_OK :
      palSetLine(LINE_LED_BLUE);
      break;
    case MSG_RESET :
    case MSG_TIMEOUT :
      palSetLine(LINE_LED_RED);
      break;
int main(void) {
  static msg_t result;
  static uint8_t counter = 0;
  static uint8_t info[5][MAILBOX_MSG_SIZE] = {"Lorem ipsum dolor sit amet, ",
                                              "consectetur adipiscing elit. ",
                                              "Nam eu mollis velit. ",
                                              "Nulla facilisi. ",
                                              "Integer ut viverra leo."};
  chMBObjectInit(&mb, mb_msg, MAILBOX_MSG_SIZE);
  chThdCreateStatic(waThdBlinker, sizeof(waThdBlinker), NORMALPRIO + 1,
                    ThdBlinker, NULL);
  while (true) {
    if (counter < 5) {
      if (chMBPostTimeout(&mb, (msg_t)info[counter], TIME_IMMEDIATE) != MSG_OK) {
      counter++;
    else {
      counter = 0;
    palToggleLine(LINE_LED_GREEN);
    chThdSleepMilliseconds(200);
When it is executed, an exception is generated.
Vector3FC:
        bl          _unhandled_exception
When I debugged the program, I verified that after creating the thread the chMBFetchTimeout() function returns the MSG_TIMEOUT value. Then, after sending three messages with the chMBPostTimeout() function, the chMBFetchTimeout() function gets the MSG_RESET value but never receives the MSG_OK value.
What am I doing wrong?
EDIT: The buffer that I used with chMBFetchTimeout() function was not defined. However, it still doesn't work.
Thank you.
1) You are getting a stack overflow in the thread.
2) The mailbox exchanges a single msg_t, not buffers.
sntnjrg
Post by sntnjrg »
Thank you Giovanni.
How can I send a buffer through mailbox?
Cheers.
Use "object FIFO", those exchange fixed-size buffers kept into a memory pool. It uses a mailbox internally so you can look at the code.
sntnjrg
Post by sntnjrg »
To initialize a FIFO object, I have to create a buffer to store all the elements of the fifo and another for the mailbox, right?
The code will be as follows:
#define FIFO_OBJ_SIZE                       64
#define FIFO_OBJ_AVAILABLE                  6
static objects_fifo_t fifo_buffer;
static char data_buffer[FIFO_OBJ_AVAILABLE][FIFO_OBJ_SIZE];
static msg_t msg_buffer[FIFO_OBJ_SIZE];
static void init_fifo_object(void) {
   chFifoObjectInit( &fifo_buffer, FIFO_OBJ_SIZE, FIFO_OBJ_AVAILABLE, data_buffer, msg_buffer);
Cheers.
Correct, make it two arrays of the same size, usually the exchanged data are structures/unions.
Internally this object includes a mailbox and a pool, so it is also an example for those.
sntnjrg
Post by sntnjrg »
Thank you Giovanni.
I have an example using a memory pool with mailbox and another using a FIFO object.
Based on your experience, What kind of solution would you recommend? a FIFO object directly or memory pool with mailbox?
Cheers.
It is the same, the FIFO IS a pool with a mailbox.
All things in OSLIB are other things aggregated in some way, the point is to not reinvent the wheel each time.
