I was complaining some time ago about H7 linker script
I have similar issue with F767ZIH. After loading the binary with the gdb:
(gdb) load
Loading section .vectors, size 0x200 lma 0x8000000
Loading section .xtors, size 0x8 lma 0x8000200
Loading section .text, size 0x89e8 lma 0x8000210
Loading section .rodata, size 0xf88 lma 0x8008bf8
Loading section .data, size 0x60c lma 0x8009b80
Start address 0x2002e8, load size 41348
Transfer rate: 32 KB/sec, 5906 bytes/write.
(gdb) b main
Note: breakpoints 1, 2, 3 and 4 also set at pc 0x208112.
Breakpoint 5 at 0x208112: file main.cpp, line 24.
(gdb) c
Continuing.
Warning:
Cannot insert breakpoint 1.
Cannot access memory at address 0x208112
Command aborted.Instead if I modify STM32F76xx.ld to use only flash0 it works just fine:
(gdb) load
Start address 0x80002e8, load size 41348
Transfer rate: 33 KB/sec, 5906 bytes/write.
(gdb) b main
Breakpoint 1 at 0x8008112: file main.cpp, line 24.
(gdb) c
Continuing.
Note: automatically using hardware breakpoints for read-only addresses.
Breakpoint 1, main () at main.cpp:24
24 halInit();Did I miss any build flag? a configuration?
Thank you
