c++ callback function in class Topic is solved
asdasd
Has thanked: 9 times
Post by asdasd »
Hi all
I am using chibios with c++ compiling but I have some problem in function callback and here is my code:
class firstclass{
firstclass (palcallback_t cb);
class secandclass{
secandclass();
void butt_cb(void *arg);
firstclass fun(butt_cb);
I don't have error if i put the function static ,but i don't want to do that .
when I have tried to write
firstclass fun(std::bind(&secandclass::butt_cb));
i failed
asd.
Re: c++ callback function in class
Callbacks must be C functions not C++ methods.
asdasd
Post by asdasd »
Giovanni wrote:Callbacks must be C functions not C++ methods.
is there any way to call in c++
steved
Has thanked: 12 times
Been thanked: 138 times
Post by steved »
Have a 1-line C function which calls the C++ function. The parameter to the callback is the object pointer.
alex31
Has thanked: 57 times
Been thanked: 88 times
Post by alex31 »
° you can also pass the address of a static member function of the class.
° another convenient way is to use captureless lambda, but you need a c++11 compliant compiler.
Alexandre
