nucleof446re demo build issue
flyingk
Post by flyingk »
Attempting to build the unmodified nucleof446re 64 demo results in
11:10:16 **** Incremental Build of configuration Default for project RT-STM32F446RE-NUCLEO64 ****
make -j11 all
Compiling chcoreasm_v7m.S
Compiling hal.c
Compiling hal_st.c
Compiling hal_buffers.c
Compiling hal_queues.c
Compiling hal_mmcsd.c
Compiling hal_pal.c
Compiling hal_serial.c
Compiling nvic.c
Compiling stm32_isr.c
Compiling hal_lld.c
Compiling stm32_dma.c
In file included from ../../ChibiOS_19.1.3/os/common/ports/ARMCMx/chcore.h:196:0,
from ../../ChibiOS_19.1.3/os/rt/include/ch.h:110,
from ../../ChibiOS_19.1.3/os/hal/osal/rt/osal.h:32,
from ../../ChibiOS_19.1.3/os/hal/include/hal.h:28,
from ../../ChibiOS_19.1.3/os/hal/src/hal.c:25:
../../ChibiOS_19.1.3/os/common/ports/ARMCMx/chcore_v7m.h:179:6: error: #error "PORT_ENABLE_GUARD_PAGES requires CH_DBG_ENABLE_STACK_CHECK"
from ../../ChibiOS_19.1.3/os/hal/src/hal_st.c:25:
from ../../ChibiOS_19.1.3/os/hal/src/hal_mmcsd.c:25:
from ../../ChibiOS_19.1.3/os/hal/src/hal_serial.c:25:
from ../../ChibiOS_19.1.3/os/hal/src/hal_pal.c:25:
from ../../ChibiOS_19.1.3/os/hal/src/hal_buffers.c:41:
from ../../ChibiOS_19.1.3/os/hal/ports/STM32/STM32F4xx/stm32_isr.c:25:
from ../../ChibiOS_19.1.3/os/hal/src/hal_queues.c:40:
from ../../ChibiOS_19.1.3/os/hal/ports/STM32/STM32F4xx/hal_lld.c:25:
from ../../ChibiOS_19.1.3/os/hal/ports/common/ARMCMx/nvic.c:25:
from ../../ChibiOS_19.1.3/os/hal/ports/STM32/LLD/DMAv2/stm32_dma.c:32:
make: *** Waiting for unfinished jobs....
make: *** [build/obj/hal_st.o] Error 1
make: *** [build/obj/hal_mmcsd.o] Error 1
make: *** [build/obj/hal_serial.o] Error 1
make: *** [build/obj/hal_pal.o] Error 1
make: *** [build/obj/stm32_isr.o] Error 1
make: *** [build/obj/hal_buffers.o] Error 1
make: *** [build/obj/hal_lld.o] Error 1
make: *** [build/obj/hal_queues.o] Error 1
make: *** [build/obj/nvic.o] Error 1
make: *** [build/obj/stm32_dma.o] Error 1
11:10:16 Build Finished (took 368ms)
Enabling this option in the chconf.h solves the issue. Is this behaviour intentional? All other demos I tried work fine out of the box.
Re: nucleof446re demo build issue
Is PORT_ENABLE_GUARD_PAGES defined in your chconf.h or Makefile? if so, remove the definition.
It is strange because it does not happen in latest 19.1.x and I don't remember fixing this.
flyingk
Post by flyingk »
yes, that option was set in chconf.h of the demo at the end. This demo was copied from the 19.1.3 tree, so it must have been forgotten there.
Cheers,
Kai
