How to use DAC1 Ch2 without dual mode Topic is solved
alex31
Has thanked: 57 times
Been thanked: 88 times
Re: How to use DAC1 Ch2 without dual mode
Post by alex31 »
I have created a ticket with a proposed patch attached.
Alexandre
I will give it a try tomorrow.
Fixed in repository, could you confirm everything is OK?
alex31
Post by alex31 »
looks fine. I was on the road this two days, I will be able to do a real test tomorrow.
thanks
Alexandre
alex31
Post by alex31 »
Tests has been done on F4 and F7 and all is working nicely !
Alexandre
sntnjrg
Has thanked: 18 times
Been thanked: 3 times
Post by sntnjrg »
I have a similar problem. I'm using a STM32L4R5ZI-NUCLEO144 board and the version 19.1.0 of ChibiOS.
My mcuconf.h have the following definitions:
 * DAC driver system settings.
#define STM32_DAC_DUAL_MODE                 FALSE
#define STM32_DAC_USE_DAC1_CH1              TRUE
#define STM32_DAC_USE_DAC1_CH2              TRUE
#define STM32_DAC_DAC1_CH1_IRQ_PRIORITY     10
#define STM32_DAC_DAC1_CH2_IRQ_PRIORITY     10
#define STM32_DAC_DAC1_CH1_DMA_PRIORITY     2
#define STM32_DAC_DAC1_CH2_DMA_PRIORITY     2
#define STM32_DAC_DAC1_CH1_DMA_STREAM       STM32_DMA_STREAM_ID_ANY
#define STM32_DAC_DAC1_CH2_DMA_STREAM       STM32_DMA_STREAM_ID_ANY
The DAC configuration is:
  static DACConfig dac_cfg = {
    // Initial output on DAC channels.
    .init         = 0U,
    // DAC data holding register mode.
    .datamode     = DAC_DHRM_8BIT_RIGHT,
    // DAC control register.
    .cr = 0
When the following code is executed, an assertion fails:
dacPutChannelX(&DACD2,1,dac_out2);
The dacPutChannelX() function contains:
void dacPutChannelX(DACDriver *dacp, dacchannel_t channel, dacsample_t sample) {
  osalDbgCheck(channel < (dacchannel_t)DAC_MAX_CHANNELS);
  osalDbgAssert(dacp->state == DAC_READY, "invalid state");
  dac_lld_put_channel(dacp, channel, sample);
channel is 1 and DAC_MAX_CHANNELS is 1.
The DAC_MAX_CHANNELS macro is defined in hal_dac_lld.h as:
 * @brief   Max DAC channels.
#if STM32_DAC_DUAL_MODE == FALSE
#define DAC_MAX_CHANNELS                    1
#else
#define DAC_MAX_CHANNELS                    2
Is it possible to use that channel with that instance of the driver? Should I use channel 0 in both instances?
dacPutChannelX(&DACD1,0,dac_out1);
dacPutChannelX(&DACD2,0,dac_out2);
It is a bug, I think the problem is here:
#else
Those two definitions are inverted. Moving this topic in bug reports.
Fixed as bug #1065.
