Getting SPI to work on STM32F7 Topic is solved
JSStabl
Has thanked: 3 times
Been thanked: 2 times
Post by JSStabl »
I'm just starting with chibiOS and I'm using the STM32F767 Nucleo-144 Board.
With ChibiStudio I have the running LED Demo Project working, now I wanted to get the SPI to work. I jused the SPI Example from the HAL examples and added it to the SMT32F767 Demo Project. SPI HAL driver was enabled I also set the SPI STM32_SPI_USE_SPI2.
Now, the SPI Threads do nothing, the Thread is not being executed (I tested it with toggling an LED there). I also connected an Osci to the D13 Port. What am I doing wrong?
I disabled the Blinker Thread, enabling that makes the LED Blink though, just to show my program compiles and start properly.
    ChibiOS - Copyright (C) 2006..2018 Giovanni Di Sirio
#include "ch.h"
#include "hal.h"
#include "rt_test_root.h"
#include "oslib_test_root.h"
/* SPI driver related.                                                       */
 * Low speed SPI configuration (421.875kHz, CPHA=0, CPOL=0, MSb first).
static const SPIConfig ls_spicfg = {
  false,
  NULL,
  GPIOB,
  GPIOB_ARD_D14,
  SPI_CR1_BR_2 | SPI_CR1_BR_1,
  SPI_CR2_DS_2 | SPI_CR2_DS_1 | SPI_CR2_DS_0
 * SPI TX and RX buffers.
 * Note, the buffer are aligned to a 32 bytes boundary because limitations
 * imposed by the data cache. Note, this is GNU specific, it must be
 * handled differently for other compilers.
#define SPI_BUFFERS_SIZE    128U
static uint8_t txbuf[SPI_BUFFERS_SIZE];
static uint8_t rxbuf[SPI_BUFFERS_SIZE];
 * SPI bus contender 1.
static THD_WORKING_AREA(spi_thread_1_wa, 256);
static THD_FUNCTION(spi_thread_1, p) {
  (void)p;
  chRegSetThreadName("SPI thread 1");
  while (true) {
    unsigned i;
    palSetLine(LINE_LED1);
    chThdSleepMilliseconds(200);
    palClearLine(LINE_LED1);
    /* Bush acquisition and SPI reprogramming.*/
    spiAcquireBus(&SPID2);
    spiStart(&SPID2, &ls_spicfg);
    /* Preparing data buffer and flushing cache.*/
    for (i = 0; i < SPI_BUFFERS_SIZE; i++)
      txbuf[i] = (uint8_t)i;
    /* Slave selection and data exchange.*/
    spiSelect(&SPID2);
    //spiExchange(&SPID2, SPI_BUFFERS_SIZE, txbuf, rxbuf);
    spiSend(&SPID2, SPI_BUFFERS_SIZE, txbuf);
    spiUnselect(&SPID2);
    /* Releasing the bus.*/
    spiReleaseBus(&SPID2);
 * This is a periodic thread that does absolutely nothing except flashing
 * a LED.
  (void)arg;
  while (true) {
    chThdSleepMilliseconds(50);
    palSetLine(LINE_LED2);
    palSetLine(LINE_LED3);
    palClearLine(LINE_LED2);
    palClearLine(LINE_LED3);
 * Application entry point.
int main(void) {
   * System initializations.
   *   RTOS is active.
   * SPI2 I/O pins setup.
  palSetLineMode(LINE_ARD_D13,
                 PAL_MODE_ALTERNATE(5) |
                 PAL_STM32_OSPEED_HIGHEST);         /* SPI SCK.             */
  palSetLineMode(LINE_ARD_D12,
                 PAL_STM32_OSPEED_HIGHEST);         /* MISO.                */
  palSetLineMode(LINE_ARD_D11,
                 PAL_STM32_OSPEED_HIGHEST);         /* MOSI.                */
  palSetLine(LINE_ARD_D15);
  palSetLineMode(LINE_ARD_D15,
                 PAL_MODE_OUTPUT_PUSHPULL);         /* CS0.                 */
  palSetLine(LINE_ARD_D14);
  palSetLineMode(LINE_ARD_D14,
                 PAL_MODE_OUTPUT_PUSHPULL);         /* CS1.                 */
   * Activates the serial driver 3 using the driver default configuration.
  sdStart(&SD3, NULL);
   * Creates the example thread.
//  chThdCreateStatic(waThread1, sizeof(waThread1), NORMALPRIO + 1, Thread1, NULL);
  chThdCreateStatic(spi_thread_1_wa, sizeof(spi_thread_1_wa),
                    NORMALPRIO, spi_thread_1, NULL);
   * sleeping in a loop and check the button state.
  while (true) {
    chThdSleepMilliseconds(500);
Debugging shows that the Code never returns after the first spiSend().
JSStabl
Re: Getting SPI to work on STM32F7
Post by JSStabl »
Got it working with SPI1, I believe the Alternate 5 is incorrect for SPI2
Thanks, moving in bug reports.
JSStabl
Post by JSStabl »
I actually still have issues with SPI 4 and 5. I can't get them to work, SPI1-3 work fine. I enabled the SPI5 in the mcuconf.h and created a new thread. I took the same configuration as for 1-3 and sent a message, however the I/Os don't do anything at all. Has anybody tested those SPI Channels on ChibiOS? Port and Bus CFG for SPI5:
    * SPID5 I/O pins setup.(Overwriting board.h configurations)
    palSetPadMode(GPIOF, 7,
                  PAL_MODE_ALTERNATE(5) | PAL_STM32_OSPEED_HIGHEST);    /* New SCK */
    palSetPadMode(GPIOF, 8,
                  PAL_MODE_ALTERNATE(5) | PAL_STM32_OSPEED_HIGHEST);    /* New MISO*/
    palSetPadMode(GPIOF, 9,
                  PAL_MODE_ALTERNATE(5) | PAL_STM32_OSPEED_HIGHEST);    /* New MOSI*/
    palSetPadMode(GPIOF, 6,
                  PAL_MODE_OUTPUT_PUSHPULL | PAL_STM32_OSPEED_HIGHEST); /* New CS*/
        false,
        NULL,
        GPIOB,
        GPIOB_ARD_D14,
        SPI_CR1_BR_2 | SPI_CR1_BR_0,
SPI1 and 5 share a buscfg, is the repeated CS Port a problem? I'm not using the select anway. Replacing SPI5 with SPI1 in the same thread works, so it's not a thread issue. For full disclosure here's the thread:
THD_WORKING_AREA(spi_thread_afe_wa, 64);
THD_FUNCTION(spi_thread_afe, p) {
    (void)p;
    chRegSetThreadName("SPI Thread AFE");
    while (true) {
        unsigned i;
        for (i = 0; i < SPI_BUFFERS_SIZE; i++){
            if(i==0){
                txbuf[i] = (uint8_t)i | 0b10000000;
            else{
        sendSPI(&SPID5);
        chThdSleepMicroseconds(200);
and this is sendSPI:
void sendSPI(SPIDriver *spip) {
    //    /* Bus acquisition and SPI reprogramming.*/
    spiAcquireBus(spip);
//    spiSelect(spip);
    spiStartSend(spip,SPI_BUFFERS_SIZE, txbuf);
//    spiUnselect(spip);
    spiReleaseBus(spip);
I haven't tested SPI6, because the pins are not routed on my Nucleo-144 board. I'm also considering if SPI4-6 aren't working on the NUCLEO-144 for some reason. They aren't mentioned in the reference manual for the board. (For they F767 they definitely exist)
JSStabl
Post by JSStabl »
Running a regular CubeMX Example produces results on SPI5, so I assume there is an issue either with my configuration (which I can't seem to find) or the HAL Driver for the STM32F7, whats the best way to debug this?
Here are the SPI status bits from the debugger
CR1 = {volatile uint32_t} 8 [0x8]
CR2 = {volatile uint32_t} 5895 [0x1707]
SR = {volatile uint32_t} 34 [0x22]
DR = {volatile uint32_t} 0 [0x0]
CRCPR = {volatile uint32_t} 7 [0x7]
RXCRCR = {volatile uint32_t} 0 [0x0]
TXCRCR = {volatile uint32_t} 0 [0x0]
I2SCFGR = {volatile uint32_t} 0 [0x0]
I2SPR = {volatile uint32_t} 0 [0x0]
You should verify the DMA channels assigned to SPIs, must not be shared. Are debug options in chconf.h enabled?
JSStabl
Post by JSStabl »
Here is the SPI config:
 * SPI driver system settings.
#define STM32_SPI_USE_SPI1                  TRUE
#define STM32_SPI_USE_SPI2                  TRUE
#define STM32_SPI_USE_SPI3                  TRUE
#define STM32_SPI_USE_SPI4                  FALSE
#define STM32_SPI_USE_SPI5                  TRUE
#define STM32_SPI_USE_SPI6                  FALSE
#define STM32_SPI_SPI1_RX_DMA_STREAM        STM32_DMA_STREAM_ID(2, 0)
#define STM32_SPI_SPI1_TX_DMA_STREAM        STM32_DMA_STREAM_ID(2, 3)
#define STM32_SPI_SPI2_RX_DMA_STREAM        STM32_DMA_STREAM_ID(1, 3)
#define STM32_SPI_SPI2_TX_DMA_STREAM        STM32_DMA_STREAM_ID(1, 4)
#define STM32_SPI_SPI3_RX_DMA_STREAM        STM32_DMA_STREAM_ID(1, 0)
#define STM32_SPI_SPI3_TX_DMA_STREAM        STM32_DMA_STREAM_ID(1, 7)
#define STM32_SPI_SPI4_RX_DMA_STREAM        STM32_DMA_STREAM_ID(2, 0)
#define STM32_SPI_SPI4_TX_DMA_STREAM        STM32_DMA_STREAM_ID(2, 1)
#define STM32_SPI_SPI5_RX_DMA_STREAM        STM32_DMA_STREAM_ID(2, 3)
#define STM32_SPI_SPI5_TX_DMA_STREAM        STM32_DMA_STREAM_ID(2, 4)
#define STM32_SPI_SPI6_RX_DMA_STREAM        STM32_DMA_STREAM_ID(2, 6)
#define STM32_SPI_SPI6_TX_DMA_STREAM        STM32_DMA_STREAM_ID(2, 5)
#define STM32_SPI_SPI1_DMA_PRIORITY         1
#define STM32_SPI_SPI2_DMA_PRIORITY         1
#define STM32_SPI_SPI3_DMA_PRIORITY         1
#define STM32_SPI_SPI4_DMA_PRIORITY         1
#define STM32_SPI_SPI5_DMA_PRIORITY         1
#define STM32_SPI_SPI6_DMA_PRIORITY         1
#define STM32_SPI_SPI1_IRQ_PRIORITY         10
#define STM32_SPI_SPI2_IRQ_PRIORITY         10
#define STM32_SPI_SPI3_IRQ_PRIORITY         10
#define STM32_SPI_SPI4_IRQ_PRIORITY         10
#define STM32_SPI_SPI5_IRQ_PRIORITY         10
#define STM32_SPI_SPI6_IRQ_PRIORITY         10
#define STM32_SPI_DMA_ERROR_HOOK(spip)      osalSysHalt("DMA failure")
Looks like the DMA is fine though. I'm using the RT-STM32F767-Nucleo144 example so it should be okay by default. Debug options seem to be disabled, which ones would be useful to enable to further diagnose the problem?
Assertions, checks, state checker.
Also define the failure mode:
- Do SPI functions return?
- Are SPI callbacks invoked?
JSStabl
Post by JSStabl »
Actually on second thought DMA(2,3) is used for SPI1 and 5. Is that an issue?
Changing the #define STM32_SPI_SPI5_RX_DMA_STREAM STM32_DMA_STREAM_ID(2, 5) worked! Thanks for the support Giovanni :)
Should we add that as a bugreport as well? Maybe we should throw a warning if the same DMA channels are used here.
You cannot use the same DMA channel on multiple peripherals and have those started at same time, an assertion is triggered in those cases.
