Bit missing for STM32L476 ? Topic is solved
Stephane
Has thanked: 2 times
Been thanked: 2 times
Post by Stephane »
Not sure, but it seems that the LPUART1_CR3, bit UCESM is missing.
Perhaps must he be in C:\ChibiStudio\chibios191\os\common\ext\ST\STM32L4xx\stm32l476xx
#define USART_CR3_UCESM_Pos           (23U)
#define USART_CR3_UCESM_Msk           (0x1U << USART_CR3_UCESM_Pos)            /*!< 0x00800000 */
#define USART_CR3_UCESM               USART_CR3_UCESM_Msk                      /*!< Clock Enable inStop Mode */
Ah, and also for the UARTs: the TCBGTIE bit ia also missing:
#define USART_CR3_TCBGTIE_Pos           (24U)
#define USART_CR3_TCBGTIE_Msk           (0x1U << USART_CR3_TCBGTIE_Pos)            /*!< 0x01000000 */
#define USART_CR3_TCBGTIE               USART_CR3_TCBGTIE_Msk                      /*!< Trm complete before guard time IRQ enable */
With best regards,
Stephane
Re: Bit missing for STM32L476 ?
That is an ST header, I will look for an updated version.
I updated the headers in trunk, they added UCESM but not the other one...
rew
Been thanked: 14 times
Post by rew »
That UESM / UECSM bit seems troublesome... Found this in the code I'm working on.
  // Bit 1 is called UESM, and documented as "reserved".... Quite
  // possible that it DOES do something. ... Update: documentation
  // error. bit not implemented.
The "not implemented" remark refers to STM32F030.
It is also possible it has been removed from documentation because some underlying problem in that feature, I don't know but it can happen.
rew
Post by rew »
Yeah, but then the bit in the register would physically exist, just not do precisely what it's supposed to do. In this case, I tested it and found the bit completely absent in the hardware.
