H7 Build Broken? Topic is solved
mrandy
H7 Build Broken?
Post by mrandy »
I think that revision 13499 broke my build for a STM32H7 project. I get these errors, which aren't present when using the previous revision:
Compiling board.c
../ChibiOS/os/hal/ports/STM32/LLD/I2Cv3/hal_i2c_lld.c: In function 'i2c_lld_start':
../ChibiOS/os/hal/ports/STM32/LLD/I2Cv3/hal_i2c_lld.c:922:18: error: 'union <anonymous>' has no member named 'bdma'; did you mean 'dma'?
         i2cp->rx.bdma = bdmaStreamAllocI(STM32_I2C_I2C4_RX_BDMA_STREAM,
                  dma
In file included from ../ChibiOS/os/rt/include/ch.h:107:0,
                 from ../ChibiOS/os/hal/osal/rt-nil/osal.h:32,
                 from ../ChibiOS/os/hal/include/hal.h:28,
                 from ../ChibiOS/os/hal/ports/STM32/LLD/I2Cv3/hal_i2c_lld.c:25:
../ChibiOS/os/hal/ports/STM32/LLD/I2Cv3/hal_i2c_lld.c:926:32: error: 'union <anonymous>' has no member named 'bdma'; did you mean 'dma'?
         osalDbgAssert(i2cp->rx.bdma != NULL, "unable to allocate stream");
../ChibiOS/os/rt/include/chdebug.h:130:11: note: in definition of macro 'chDbgAssert'
     if (!(c)) {                                                             \
../ChibiOS/os/hal/ports/STM32/LLD/I2Cv3/hal_i2c_lld.c:926:9: note: in expansion of macro 'osalDbgAssert'
../ChibiOS/os/hal/ports/STM32/LLD/I2Cv3/hal_i2c_lld.c:927:18: error: 'union <anonymous>' has no member named 'bdma'; did you mean 'dma'?
         i2cp->tx.bdma = bdmaStreamAllocI(STM32_I2C_I2C4_TX_BDMA_STREAM,
                  dma
../ChibiOS/os/hal/ports/STM32/LLD/I2Cv3/hal_i2c_lld.c:931:32: error: 'union <anonymous>' has no member named 'bdma'; did you mean 'dma'?
         osalDbgAssert(i2cp->tx.bdma != NULL, "unable to allocate stream");
     if (!(c)) {                                                             \
../ChibiOS/os/hal/ports/STM32/LLD/I2Cv3/hal_i2c_lld.c:931:9: note: in expansion of macro 'osalDbgAssert'
../ChibiOS/os/hal/ports/STM32/LLD/I2Cv3/hal_i2c_lld.c:935:39: error: 'union <anonymous>' has no member named 'bdma'; did you mean 'dma'?
         bdmaSetRequestSource(i2cp->rx.bdma, STM32_DMAMUX2_I2C4_RX);
                                       dma
../ChibiOS/os/hal/ports/STM32/LLD/I2Cv3/hal_i2c_lld.c:936:39: error: 'union <anonymous>' has no member named 'bdma'; did you mean 'dma'?
         bdmaSetRequestSource(i2cp->tx.bdma, STM32_DMAMUX2_I2C4_TX);
                                       dma
../ChibiOS/os/common/startup/ARMCMx/compilers/GCC/mk/rules.mk:189: recipe for target 'build/obj/hal_i2c_lld.o' failed
FXCoder
Has thanked: 188 times
Been thanked: 134 times
Re: H7 Build Broken?
Post by FXCoder »
Thanks for the report.
It will be fixed in trunk ASAP.
BTW were you using I2C4 or just had it enabled but not in active use?
Bob
mrandy
Post by mrandy »
It's currently enabled but not referenced anywhere. I plan on using it eventually, because the board I'm writing code for has a device on I2C4, it's not in my code at the moment.
FXCoder
Post by FXCoder »
Fixed in trunk as bug #1082.
