Cortex-M0 bugs: 88167, 88656
jpyka
Re: Cortex-M0 bugs: 88167, 88656
Post by jpyka »
I'm using latest ARM toolchain 9-2020-q2-update version released on 29th of May.
Can you please confirm that both issues: 88167, 88656 are already fixed in the gcc compiler (9.3.1) from that toolchain and so the below check & warning I got in ChibiOS ARMv6-M port is not relevant any more ?
#warning "This compiler has a know problem with Cortex-M0, see bugs: 88167, 88656."
#warning "*** Use GCC version 5 or below ***"
Both have been fixed (it is the same issue, they have 2 tickets), the warning message will be removed in next release, just ignore it.
