Writing to Internal Flash on STM32F767
JSStabl
Has thanked: 3 times
Been thanked: 2 times
Post by JSStabl »
I'm trying to use the internal flash on the F767 to write/read some configuration data. However I'm confused as how to accomplish that, i.e. which driver to use. I figured out that the MFS file system driver is useful for this but I'm not entirely sure if I need the EFL Driver and how to configure it properly. If I need that I would have to update from 19.x to 20.x I assume. Is there a guide on how to update between versions?
Re: Writing to Internal Flash on STM32F767
Currently there is no EFL driver for the F7 and you need it, MFS sits on top of an EFL driver in order to provide storage abstraction but it is EFL that performs flash operations.
There is an example under \testhal\STM32\multi\EFL-MFS, it supports only L4 so far but it could be easily extended to any device supporting an EFL driver.
JSStabl
Post by JSStabl »
Is the port for the EFL Driver to different uC planned for future versions?
There are no immediate plans for it, all those EFL drivers were contributed by users. Probably it could be derived by the driver of another device, F4 or L4, the closer one in terms of flash organization.
