STM32WB55 support
Re: STM32WB55 support
OK, I will look closer at the clocks. Thanks!
As far as OpenOCD goes, there does appear to be support added earlier this year (looking through commit emails, I see a few commits that claim adding various features for both STM32WB5x and STM32WB3x), though I will admit I haven't used OpenOCD on this board yet.
Hi riz94107,
I didn't test USB, however I have added basic clock initialization for it. I can rebase my changes on top of the latest version of the subversion trunk and verify USB. Please, keep in mind that I'm still working on adding IPCC/HSE support needed for communication with the radio stack running in CPU2.
OpenOCD 0.10.0 supports STM32WB without enabling `-rtos auto`. I use the following command to attach:
However, I noticed that the `-c "stm32wbx.cpu configure -rtos auto"` flag, which provides an ability to see a list of threads, doesn't properly work after the following change:
Which fails with the following:
Best regards,
Ilya.
openocd --search ~/openocd/scripts -f board/st_nucleo_wb55.cfgHowever, I noticed that the `-c "stm32wbx.cpu configure -rtos auto"` flag, which provides an ability to see a list of threads, doesn't properly work after the following change:
svn://svn.code.sf.net/p/chibios/svn/trunk@13496Which fails with the following:
Error: ChibiOS registry integrity check failed, double linked list violation
Info : Only showing current execution because of a broken ChibiOS thread registry.
Info : Unable to match requested speed 500 kHz, using 480 kHz
xPSR: 0x01000000 pc: 0x08000218 msp: 0x20000400
Info : Only showing current execution because of a broken ChibiOS thread registry.Best regards,
Ilya.
Interesting progress and would be useful for upcoming projects I have.
Could IPCC & HSE become ChibiOS drivers since these are needed for STM32WL as well?
We'll get Giovanni's comments on that...
Bob
Bob
Those could become helper drivers, like DMAs, for sure but not "abstract" high level drivers in the HAL, too specific.
Giovanni,
Sounds good on the helper driver approach for IPCC and HSE
How about proceeding as follows:
1. Add the latest WB55 work by Ilya to trunk.
2. Then WB standard peripheral work/fixes continue as required in trunk.
3. The iPCC and HSE helper drivers can be started (get implementation clues out of CUBE).
4. WL can be started (not too different to WB) and put into trunk.
I can assist with above as time permits.
Bob
Bob
I wanted to do the clock tree like in L5 and G4, this could take a bit of extra work if you start from the code as it is now.
Hi Ilya,
There is nothing wrong, if you look at the latest G4 and L5 ports you can see that there is a lot less code in hal_lld.h/c because both ports include common parts from LLD/RCCv1. If WB is close enough to L5/G4 then it could do the same thing, if it is different then a RCCv2 may be required.
The idea is to minimize code duplication in clock initialization so all new ports use this new system, it would be strange to introduce a new port and not use it, with time I will rework also some of the old ones.
I will give it a try very soon starting from your code, I have the board already.
Thank you for the details about RCCv1, it makes sense. I've attached the tarball with previous changes rebased on top of the trunk and in addition to that I've update chconfigs for included demos and tests (ADC, RTC and TRNG) which I manually verified.
Best regards,
Ilya.
Best regards,
Ilya.
- STM32WB55xx-b76f7a.zip
- STM32WB55 with demos and tests (ADC, RTC and TRNG)
- (344.92 KiB) Downloaded 458 times
I merged all the 21
patches with very minor changes, could you validate it works correctly before evaluating changes along the lines of G4/L5?
I merged all the 21
